[petsc-dev] -on_error_attach_debugger
Jed Brown
jed at jedbrown.org
Fri Jul 3 07:20:27 CDT 2020
Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
> Hello,
> (Probably nobody cares, but) it looks like -on_error_attach_debugger is neither “-malloc_dump"-clean nor valgrind-clean.
Any reason not to pop it in PetscFinalize? We'd normally do that via PetscRegisterFinalize/PetscSysFinalizePackage, but perhaps it should be done manually so it can be "last" (at least after the package finalization).
> $ cd src/ksp/ksp/tutorials
> $ ~/petsc/arch-darwin-c-debug-real/bin/mpiexec -n 2 valgrind --leak-check=full --show-leak-kinds=all ./ex2 -on_error_attach_debugger
> Norm of error 0.000411674 iterations 7
> ==2074== 24 bytes in 1 blocks are still reachable in loss record 1 of 1
> ==2074== at 0x483E340: memalign (in /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==2074== by 0x4A80902: PetscMallocAlign (mal.c:49)
> ==2074== by 0x4A822E8: PetscMallocA (mal.c:422)
> ==2074== by 0x4AD2B45: PetscPushErrorHandler (err.c:161)
> ==2074== by 0x4B1D47B: PetscOptionsCheckInitial_Private (init.c:545)
> ==2074== by 0x4B25AE7: PetscInitialize (pinit.c:1019)
> ==2074== by 0x10B4FA: main (ex2.c:31)
> $ ~/petsc/arch-darwin-c-debug-real/bin/mpiexec -n 2 ./ex2 -on_error_attach_debugger -malloc_dump
> [ 0]32 bytes PetscPushErrorHandler() line 161 in /home/john/petsc/src/sys/error/err.c
> [ 1]32 bytes PetscPushErrorHandler() line 161 in /home/john/petsc/src/sys/error/err.c
> Thanks,
> Pierre
