[petsc-dev] CI update: please rebase before starting test pipelines
    Satish Balay
    balay at mcs.anl.gov
    Thu Jan 30 11:10:14 CST 2020
To clarify:
CI uses .gitlab-ci.yaml from the branch - and not the latest from
maint/master - so if your branch has old version of this file, and start
a pipeline on it - it will get stuck - and timeout.
To determine if your branch has this .gitlab-ci.yaml change [requiring
a rebase] - see if it has the commit:
git branch --contains 0b416d8e105a765da5769e4b7feab5986dc829a2
Satish
On Wed, 29 Jan 2020, Balay, Satish via petsc-dev wrote:
> PETSc devs using CI at gitlab,
> With the current CI changes - before starting a test pipeline on a
> branch at gitlab, its best to rebase the branch over current master as
> of now [or maint - if appropriate].
> If a test pipeline is created with non-rebased branch, some of the
> stage-2 jobs will be stuck - so the pipeline won't complete.
> Satish
