[petsc-dev] complex fix and -Wfloat-equal
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Jan 29 23:25:47 CST 2020
> On Jan 27, 2020, at 3:42 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> I usually compile my code with almost most warning flags on, including -Wfloat-equal.
> My implementation of the C++ complex fix that is not included by default is an obvious offender (see warning messages at the end).
> A simple fix (and I think it is a safe one, same thing is used in the boost libraries, https://www.boost.org/doc/libs/1_72_0/boost/config/detail/suffix.hpp) that works with both GCC and clang (and most likely Intel, I'll try tomorrow) is the following:
> diff --git a/include/petsccxxcomplexfix.h b/include/petsccxxcomplexfix.h
> index d3614e8a62..3c3090215b 100644
> --- a/include/petsccxxcomplexfix.h
> +++ b/include/petsccxxcomplexfix.h
> @@ -35,6 +35,10 @@
> before including any PETSc include files to prevent these methods from being provided.
> +#if defined(__GNUC__) && (__GNUC__ >= 4)
> +#pragma GCC system_header
> +#endif
> #define PETSC_CXX_COMPLEX_FIX(Type) \
> static inline PetscComplex operator+(const PetscComplex& lhs, const Type& rhs) { return const_cast<PetscComplex&>(lhs) + PetscReal(rhs); } \
> static inline PetscComplex operator+(const Type& lhs, const PetscComplex& rhs) { return PetscReal(lhs) + const_cast<PetscComplex&>(rhs); } \
> Would that be an acceptable solution o we should rather implement a configure test and define PETSC_HAVE_PRAGMA_GCC_SYSTEM_HEADER ?
I'm fine with having it handled by the version check.
> These are the kind of errors that show up for EVERY C++ source compile if -Wfloat-equal is passed.
> /home/devel/petsc/dev/include/petsccxxcomplexfix.h: In function ‘bool operator==(const PetscComplex&, const PetscInt&)’:
> /home/devel/petsc/dev/include/petsccxxcomplexfix.h:47:134: warning: comparing floating point with == or != is unsafe [-Wfloat-equal]
> 47 | static inline bool operator==(const PetscComplex& lhs, const Type& rhs) { return const_cast<PetscComplex&>(lhs).imag() == PetscReal(0) && const_cast<PetscComplex&>(lhs).real() == PetscReal(rhs); } \
> /home/devel/petsc/dev/include/petsccxxcomplexfix.h:60:1: note: in expansion of macro ‘PETSC_CXX_COMPLEX_FIX’
> 60 | PETSC_CXX_COMPLEX_FIX(PetscInt)
I don't understand the above. Are these two unrelated issues? Or does adding the first chunk of code prevent the warnings from the second chunk of code.
Barry
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
