[petsc-dev] PETSC_HAVE_PRAGMA_DISJOINT
Jed Brown
jed at jedbrown.org
Mon Jan 27 17:22:33 CST 2020
Looks stale to me. If we're going to keep this sort of thing, I would
prefer to do it using _Pragma instead of needing all the #ifdef. In
this case, restrict qualification should be sufficient.
Lisandro Dalcin <dalcinl at gmail.com> writes:
> Is this a stale macroi? Where is the configure code for it?
> $ git grep 'PRAGMA_DISJOINT'
> src/mat/impls/aij/seq/aij.c:#if defined(PETSC_HAVE_PRAGMA_DISJOINT)
> src/mat/impls/aij/seq/aijperm/aijperm.c:#if
> src/mat/impls/aij/seq/crl/crl.c:#if defined(PETSC_HAVE_PRAGMA_DISJOINT)
> src/mat/impls/aij/seq/inode.c:#if defined(PETSC_HAVE_PRAGMA_DISJOINT)
> src/mat/impls/baij/seq/baij2.c:#if defined(PETSC_HAVE_PRAGMA_DISJOINT)
> src/mat/impls/sell/seq/sell.c:#if defined(PETSC_HAVE_PRAGMA_DISJOINT)
> src/vec/vec/impls/seq/dvec2.c:#if defined(PETSC_HAVE_PRAGMA_DISJOINT)
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
