[petsc-dev] Issue with dependency generation in GCC 9
Lisandro Dalcin dalcinl at gmail.com
Mon Jan 20 13:30:10 CST 2020
Indeed! First bug fix listed here:
https://ccache.dev/releasenotes.html#_ccache_3_7_7
Thanks all and sorry for the noise!
On Mon, 20 Jan 2020 at 21:33, Balay, Satish <balay at mcs.anl.gov> wrote:
> And looks like the issue is fixed in ccache 3.7.7
> Satish
> balay at sb /home/balay/petsc (master=)
> $ which gcc
> /usr/lib64/ccache/gcc
> $ ccache --version
> ccache version 3.7.7
> Copyright (C) 2002-2007 Andrew Tridgell
> Copyright (C) 2009-2020 Joel Rosdahl
> This program is free software; you can redistribute it and/or modify it
> under
> the terms of the GNU General Public License as published by the Free
> Software
> Foundation; either version 3 of the License, or (at your option) any later
> version.
> $ make clean
> /usr/bin/rm -f -r ./arch-linux-c-debug/tests
> ./arch-linux-c-debug/tests/testfiles
> /usr/bin/rm -f -r arch-linux-c-debug/obj arch-linux-c-debug/lib/libpetsc*
> /home/balay/petsc/arch-linux-c-debug/include/petsc*.mod
> arch-linux-c-debug/lib/petsc/conf/files
> $ make -f gmakefile arch-linux-c-debug/obj/sys/objects/init.o
> /usr/bin/python ./config/gmakegen.py --petsc-arch=arch-linux-c-debug
> /usr/bin/python /home/balay/petsc/config/gmakegentest.py
> --petsc-dir=/home/balay/petsc --petsc-arch=arch-linux-c-debug
> --testdir=./arch-linux-c-debug/tests
> Use "/usr/bin/gmake V=1" to see verbose compile lines, "/usr/bin/gmake
> V=0" to suppress.
>           CC arch-linux-c-debug/obj/sys/objects/init.o
> $ head -n 3 arch-linux-c-debug/obj/sys/objects/init.d
> arch-linux-c-debug/obj/sys/objects/init.o: \
>  /home/balay/petsc/src/sys/objects/init.c \
>  /home/balay/petsc/include/petscsys.h \
> make: 'arch-linux-c-debug/obj/sys/objects/init.o' is up to date.
> $ touch /home/balay/petsc/include/petscsys.h
> V=0" to suppress.
> On Mon, 20 Jan 2020, Balay, Satish via petsc-dev wrote:
> > Downgrading to ccache-3.4.3-2.fc30.x86_64.rpm [on F31] changes this
> behavior for me.
> > Satish
> > wget
> https://kojipkgs.fedoraproject.org//packages/ccache/3.4.3/2.fc30/x86_64/ccache-3.4.3-2.fc30.x86_64.rpm
> > rpm -Uvh --oldpackage ccache-3.4.3-2.fc30.x86_64.rpm
> > On Mon, 20 Jan 2020, Lisandro Dalcin wrote:
> > > Ups! Not a GCC issue, but still relevant to all us...
> > > The issue happens only if using ccache. I have the system ccache
> package
> > > installed, and ccache is used via symlinks.
> > > $ mpicc -show
> > > gcc -I/usr/include/mpich-x86_64 -L/usr/lib64/mpich/lib -Wl,-rpath
> > > -Wl,/usr/lib64/mpich/lib -Wl,--enable-new-dtags -lmpi
> > > $ which gcc
> > > Rebuilding this way:
> > > $ make clean
> > > $ MPICH_CC=/usr/bin/gcc make
> > > $ head -n 3 arch-linux2-c-debug/obj/sys/objects/init.d
> > > arch-linux2-c-debug/obj/sys/objects/init.o: \
> > >  /home/devel/petsc/dev/src/sys/objects/init.c \
> > >  /home/devel/petsc/dev/include/petscsys.h \
> > > so I'm back to normal.
> > > Now I need to figure out if this is a ccache miss-configuration (maybe
> from
> > > legacy values in my $HOME config file) or something else.
> > > On Mon, 20 Jan 2020 at 18:42, <jed at jedbrown.org> wrote:
> > > > Ah, you're right. I'm still suspicious about how this behavior
> appeared on
> > > > your machine. Would be interesting to check a vanilla build or gcc-10
> > > > branch. I'm still learning toward it being unintentional.
> > > > On Jan 20, 2020 07:57, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > > > On Mon, 20 Jan 2020 at 17:07, Jed Brown <jed at jedbrown.org> wrote:
> > > > From my man page (contradicting the behavior Lisandro observed):
> > > >    -MD -MD is equivalent to -M -MF file, except that -E is not
> implied.
> > > > The driver
> > > >        determines file based on whether an -o option is given.  If
> it is,
> > > > the driver uses
> > > >        its argument but with a suffix of .d, otherwise it takes the
> name
> > > > of the input
> > > >        file, removes any directory components and suffix, and
> applies a .d
> > > > suffix.
> > > > Lisandro, what does your man page say?
> > > > It says exactly the same. But you are confusing the flag, -MF is
> about
> > > > naming the output dep filename, i.e.
> ompi-optg/obj/sys/objects/init.d in
> > > > your example, that is just fine, I do get that file with that name.
> > > > My issue is with the contents GCC writes within that dep file,
> > > > specifically the TARGET, which can be specified with -MT, but it is
> > > > cumbersome to do, unless you use "-MT $@", though no idea how to
> update
> > > > configure for that.
> > > > Lisandro Dalcin
> > > > Research Scientist
> > > > Extreme Computing Research Center (ECRC)
> > > > King Abdullah University of Science and Technology (KAUST)
> > > > http://ecrc.kaust.edu.sa/
Lisandro Dalcin
Research Scientist
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200120/a34f8860/attachment.html>
