[petsc-dev] Issue with dependency generation in GCC 9
    Matthew Knepley
    knepley at gmail.com
    Mon Jan 20 09:01:49 CST 2020
On Mon, Jan 20, 2020 at 9:58 AM Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On Mon, 20 Jan 2020 at 17:07, Jed Brown <jed at jedbrown.org> wrote:
>> From my man page (contradicting the behavior Lisandro observed):
>>    -MD -MD is equivalent to -M -MF file, except that -E is not implied.
>> The driver
>>        determines file based on whether an -o option is given.  If it is,
>> the driver uses
>>        its argument but with a suffix of .d, otherwise it takes the name
>> of the input
>>        file, removes any directory components and suffix, and applies a
>> .d suffix.
>> Lisandro, what does your man page say?
> It says exactly the same. But you are confusing the flag, -MF is about
> naming the output dep filename, i.e. ompi-optg/obj/sys/objects/init.d in
> your example, that is just fine, I do get that file with that name.
> My issue is with the contents GCC writes within that dep file,
> specifically the TARGET, which can be specified with -MT, but it is
> cumbersome to do, unless you use "-MT $@", though no idea how to update
> configure for that.
Here is the test:
https://gitlab.com/petsc/petsc/blob/master/config/BuildSystem/config/compilers.py#L1345
We need to update it to break with your compiler, and then add another line
with the -MT.
     Matt
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200120/064b3919/attachment.html>
