[petsc-dev] ccache tips?
    Matthew Knepley
    knepley at gmail.com
    Fri Jan 17 10:32:35 CST 2020
I configured MPI with CC="ccache gcc"
knepley/feature-dm-remove-hybrid *$:/PETSc3/petsc/petsc-dev$
/PETSc3/petsc/bin/mpicc -show
/Users/knepley/MacSoftware/bin/ccache gcc -Qunused-arguments
-fstack-protector -Qunused-arguments -g3 -Wl,-flat_namespace
-I/PETSc3/petsc/include -L/PETSc3/petsc/lib -lpmpich -lmpic
h -lopa -lmpl -lpthread
and then used --with-mpi-dir. This is the way to go if you do multiple
ARCHes. Have not had a problem on OSX or Linux. Works with all packages.
   Matt
On Fri, Jan 17, 2020 at 11:29 AM Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> I'm shamefully not using ccache. How do I do it? Is it as simple as
> ./configure --with-cc="ccache gcc" --with-cxx="ccache g++"? Works on OS X
> and various Linuxes? Any known issue with external packages or otherwise?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200117/1aa1ad18/attachment.html>
