[petsc-dev] Exodus viewer
Matthew Knepley
knepley at gmail.com
Tue Feb 25 11:29:16 CST 2020
On Tue, Feb 25, 2020 at 10:44 AM Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> I just noticed recent changes to the exodus I/O and a new exodus viewer,
> which had been on my todo list forever…
> Is there a test or example available? Is there anything that remains I
> could help with?
I know! It was on mine too. I have not output fields or all the labels, so
outputting them would be a big help. You should be able to
just use -dm_view exodusii anywhere we output. If you do the fields, then
vec_view exodusii would also work. I can help with any
PETSc thing that is obscure.
Matt
> Regards,
> Blaise
> A.K. & Shirley Barton Professor of Mathematics
> Adjunct Professor of Mechanical Engineering
> Adjunct of the Center for Computation & Technology
> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803,
> USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 Web
> http://www.math.lsu.edu/~bourdin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200225/cfcb037c/attachment.html>
