[petsc-dev] Proper matrix size to choose when evaluating MatMult?
Junchao Zhang jczhang at mcs.anl.gov
Sat Feb 22 07:49:06 CST 2020
On Fri, Feb 21, 2020 at 6:41 PM Matthew Knepley <knepley at gmail.com> wrote:
> I think Karl goes into these issues here:
> https://arxiv.org/pdf/1410.4054.pdf
Wonderful, thanks.
>   Thanks,
>     Matt
> On Fri, Feb 21, 2020 at 5:58 PM Junchao Zhang via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> On Fri, Feb 21, 2020 at 4:38 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> On Fri, Feb 21, 2020 at 4:51 PM Junchao Zhang via petsc-dev <
>>>> Hello,
>>>> I want to evaluate MatMult on GPU.  I took a 2M x 2M matrix and ran
>>>> with 6 mpi ranks and 6 GPUs.  It took about 0.9 seconds.  A kernel launch
>>>> or a stream synchronization took about 10us.
>>> Your call, but you should run the code once and then run it in a new
>>> timer. I've seen some big "warm up costs" GPUs today.
>> Yes, I usually run hundreds iterations and skip the first few. Thanks.
>>>> Compared with MatMult, they are tiny. Does it mean we can ignore them?
>>>> What is a proper size to evaluate MatMult?
>>> It depends on the purpose/audience for the study. There is no right size
>>> other than being much larger than the launch cost, perhaps.
>>>> I heard it is a few thousand rows per MPI rank.  Why?
>>>> Thanks.
>>>> --Junchao Zhang
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200222/90f8fbc6/attachment-0001.html>
