[petsc-dev] Proper matrix size to choose when evaluating MatMult?
Junchao Zhang
jczhang at mcs.anl.gov
Fri Feb 21 16:57:42 CST 2020
On Fri, Feb 21, 2020 at 4:38 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, Feb 21, 2020 at 4:51 PM Junchao Zhang via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> Hello,
>> I want to evaluate MatMult on GPU. I took a 2M x 2M matrix and ran with
>> 6 mpi ranks and 6 GPUs. It took about 0.9 seconds. A kernel launch or a
>> stream synchronization took about 10us.
> Your call, but you should run the code once and then run it in a new
> timer. I've seen some big "warm up costs" GPUs today.
Yes, I usually run hundreds iterations and skip the first few. Thanks.
>> Compared with MatMult, they are tiny. Does it mean we can ignore them?
>> What is a proper size to evaluate MatMult?
> It depends on the purpose/audience for the study. There is no right size
> other than being much larger than the launch cost, perhaps.
>> I heard it is a few thousand rows per MPI rank. Why?
>> Thanks.
>> --Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200221/bf665ada/attachment.html>
