[petsc-dev] First call to cudaMalloc or cudaFree is very slow on summit
    Junchao Zhang
    jczhang at mcs.anl.gov
    Mon Feb 10 10:44:54 CST 2020
As I mentioned, have you tried -cuda_initialize 0? Also,
PetscCUDAInitialize contains
ierr = PetscCUBLASInitializeHandle();CHKERRQ(ierr);
ierr = PetscCUSOLVERDnInitializeHandle();CHKERRQ(ierr);
Have you tried to comment out them and test again?
--Junchao Zhang
On Sat, Feb 8, 2020 at 5:22 PM Zhang, Hong via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> On Feb 8, 2020, at 5:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Feb 8, 2020 at 4:34 PM Zhang, Hong via petsc-dev <
>> I did some further investigation. The overhead persists for both the
>> PETSc shared library and the static library. In the previous example, it
>> does not call any PETSc function, the first CUDA function becomes very slow
>> when it is linked to the petsc so. This indicates that the slowdown occurs
>> if the symbol (cudafree)is searched through the petsc so, but does not
>> occur if the symbol is found directly in the cuda runtime lib.
>> So the issue has nothing to do with the dynamic linker. The following
>> example can be used to easily reproduce the problem (cudaFree(0) always
>> takes ~7.5 seconds).
> 1) This should go to OLCF admin as Jeff suggests
> I had sent this to OLCF admin before the discussion was started here.
> Thomas Papatheodore has followed up. I am trying to help him reproduce the
> problem on summit.
> 2) Just to make sure I understand, a static executable with this code is
> still slow on the cudaFree(), since CUDA is a shared library by default.
> I prepared the code as a minimal example to reproduce the problem. It
> would be fair to say any code using PETSc (with CUDA enabled, built
> statically or dynamically) on summit suffers a 7.5-second overhead on the
> first CUDA function call (either in the user code or inside PETSc).
> Thanks,
> Hong
> I think we should try:
>   a) Forcing a full static link, if possible
>   b) Asking OLCF about link resolution order
> It sounds like a similar thing I have seen in the past where link
> resolution order can exponentially increase load time.
>   Thanks,
>      Matt
>> bash-4.2$ cat ex_simple_petsc.c
>> #include <time.h>
>> #include <cuda_runtime.h>
>> #include <stdio.h>
>> #include <petscmat.h>
>> int main(int argc,char **args)
>>   clock_t start,s1,s2,s3;
>>   double  cputime;
>>   double  *init,tmp[100] = {0};
>>   PetscErrorCode ierr=0;
>>   ierr = PetscInitialize(&argc,&args,(char*)0,NULL);if (ierr) return ierr;
>>   start = clock();
>>   cudaFree(0);
>>   s1 = clock();
>>   cudaMalloc((void **)&init,100*sizeof(double));
>>   s2 = clock();
>>   cudaMemcpy(init,tmp,100*sizeof(double),cudaMemcpyHostToDevice);
>>   s3 = clock();
>>   printf("free time =%lf malloc time =%lf copy time =%lf\n",((double) (s1
>> - start)) / CLOCKS_PER_SEC,((double) (s2 - s1)) / CLOCKS_PER_SEC,((double)
>> (s3 - s2)) / CLOCKS_PER_SEC);
>>   ierr = PetscFinalize();
>>   return ierr;
>> Hong
>> On Feb 7, 2020, at 3:09 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
>> Note that the overhead was triggered by the first call to a CUDA
>> function. So it seems that the first CUDA function triggered loading petsc
>> so (if petsc so is linked), which is slow on the summit file system.
>> Hong
>> On Feb 7, 2020, at 2:54 PM, Zhang, Hong via petsc-dev <
>> Linking any other shared library does not slow down the execution. The
>> PETSc shared library is the only one causing trouble.
>> Here are the ldd output for two different versions. For the first
>> version, I removed -lpetsc and it ran very fast. The second (slow) version
>> was linked to petsc so.
>> bash-4.2$ ldd ex_simple
>>         linux-vdso64.so.1 =>  (0x0000200000050000)
>>         liblapack.so.0 =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/liblapack.so.0
>> (0x0000200000070000)
>>         libblas.so.0 =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libblas.so.0
>> (0x00002000009b0000)
>>         libhdf5hl_fortran.so.100 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/hdf5-1.10.3-pgiul2yf4auv7krecd72t6vupd7e3qgn/lib/libhdf5hl_fortran.so.100
>> (0x0000200000e80000)
>>         libhdf5_fortran.so.100 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/hdf5-1.10.3-pgiul2yf4auv7krecd72t6vupd7e3qgn/lib/libhdf5_fortran.so.100
>> (0x0000200000ed0000)
>>         libhdf5_hl.so.100 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/hdf5-1.10.3-pgiul2yf4auv7krecd72t6vupd7e3qgn/lib/libhdf5_hl.so.100
>> (0x0000200000f50000)
>>         libhdf5.so.103 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/hdf5-1.10.3-pgiul2yf4auv7krecd72t6vupd7e3qgn/lib/libhdf5.so.103
>> (0x0000200000fb0000)
>>         libX11.so.6 => /usr/lib64/libX11.so.6 (0x00002000015e0000)
>>         libcufft.so.10 => /sw/summit/cuda/10.1.168/lib64/libcufft.so.10
>> (0x0000200001770000)
>>         libcublas.so.10 => /sw/summit/cuda/10.1.168/lib64/libcublas.so.10
>> (0x0000200009b00000)
>>         libcudart.so.10.1 =>
>> /sw/summit/cuda/10.1.168/lib64/libcudart.so.10.1 (0x000020000d950000)
>>         libcusparse.so.10 =>
>> /sw/summit/cuda/10.1.168/lib64/libcusparse.so.10 (0x000020000d9f0000)
>>         libcusolver.so.10 =>
>> /sw/summit/cuda/10.1.168/lib64/libcusolver.so.10 (0x0000200012f50000)
>>         libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x000020001dc40000)
>>         libdl.so.2 => /usr/lib64/libdl.so.2 (0x000020001ddd0000)
>>         libpthread.so.0 => /usr/lib64/libpthread.so.0 (0x000020001de00000)
>>         libmpiprofilesupport.so.3 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libmpiprofilesupport.so.3
>> (0x000020001de40000)
>>         libmpi_ibm_usempi.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libmpi_ibm_usempi.so
>> (0x000020001de70000)
>>         libmpi_ibm_mpifh.so.3 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libmpi_ibm_mpifh.so.3
>> (0x000020001dea0000)
>>         libmpi_ibm.so.3 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libmpi_ibm.so.3
>> (0x000020001df40000)
>>         libpgf90rtl.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgf90rtl.so
>> (0x000020001e0b0000)
>>         libpgf90.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgf90.so
>> (0x000020001e0f0000)
>>         libpgf90_rpm1.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgf90_rpm1.so
>> (0x000020001e6a0000)
>>         libpgf902.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgf902.so
>> (0x000020001e6d0000)
>>         libpgftnrtl.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgftnrtl.so
>> (0x000020001e700000)
>>         libatomic.so.1 => /usr/lib64/libatomic.so.1 (0x000020001e730000)
>>         libpgkomp.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgkomp.so
>> (0x000020001e760000)
>>         libomp.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libomp.so
>> (0x000020001e790000)
>>         libomptarget.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libomptarget.so
>> (0x000020001e880000)
>>         libpgmath.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgmath.so
>> (0x000020001e8b0000)
>>         libpgc.so =>
>> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linuxpower/19.4/lib/libpgc.so
>> (0x000020001e9d0000)
>>         librt.so.1 => /usr/lib64/librt.so.1 (0x000020001eb40000)
>>         libm.so.6 => /usr/lib64/libm.so.6 (0x000020001eb70000)
>>         libgcc_s.so.1 => /usr/lib64/libgcc_s.so.1 (0x000020001ec60000)
>>         libc.so.6 => /usr/lib64/libc.so.6 (0x000020001eca0000)
>>         libz.so.1 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/zlib-1.2.11-2htm7ws4hgrthi5tyjnqxtjxgpfklxsc/lib/libz.so.1
>> (0x000020001ee90000)
>>         libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x000020001eef0000)
>>         /lib64/ld64.so.2 (0x0000200000000000)
>>         libcublasLt.so.10 =>
>> /sw/summit/cuda/10.1.168/lib64/libcublasLt.so.10 (0x000020001ef40000)
>>         libutil.so.1 => /usr/lib64/libutil.so.1 (0x0000200020e50000)
>>         libhwloc_ompi.so.15 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libhwloc_ompi.so.15
>> (0x0000200020e80000)
>>         libevent-2.1.so.6 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libevent-2.1.so.6
>> (0x0000200020ef0000)
>>         libevent_pthreads-2.1.so.6 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libevent_pthreads-2.1.so.6
>> (0x0000200020f70000)
>>         libopen-rte.so.3 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libopen-rte.so.3
>> (0x0000200020fa0000)
>>         libopen-pal.so.3 =>
>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/pgi-19.4/spectrum-mpi-10.3.0.1-20190611-4ymaahbai7ehhw4rves5jjiwon2laz3a/lib/libopen-pal.so.3
>> (0x00002000210b0000)
>>         libXau.so.6 => /usr/lib64/libXau.so.6 (0x00002000211a0000)
>> bash-4.2$ ldd ex_simple_slow
>>         libpetsc.so.3.012 =>
>> /autofs/nccs-svm1_home1/hongzh/Projects/petsc/arch-olcf-summit-sell-opt/lib/libpetsc.so.3.012
>>         liblapack.so.0 =>
>> (0x0000200002be0000)
>>         libblas.so.0 =>
>> (0x0000200003520000)
>> (0x00002000039f0000)
>> (0x0000200003a40000)
>> (0x0000200003ac0000)
>>         libhdf5.so.103 =>
>> (0x0000200003b20000)
>>         libX11.so.6 => /usr/lib64/libX11.so.6 (0x0000200004150000)
>> (0x00002000042e0000)
>> (0x000020000c670000)
>> /sw/summit/cuda/10.1.168/lib64/libcudart.so.10.1 (0x00002000104c0000)
>> /sw/summit/cuda/10.1.168/lib64/libcusparse.so.10 (0x0000200010560000)
>> /sw/summit/cuda/10.1.168/lib64/libcusolver.so.10 (0x0000200015ac0000)
>>         libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002000207b0000)
>>         libdl.so.2 => /usr/lib64/libdl.so.2 (0x0000200020940000)
>>         libpthread.so.0 => /usr/lib64/libpthread.so.0 (0x0000200020970000)
>> (0x00002000209b0000)
>> (0x00002000209e0000)
>> (0x0000200020a10000)
>>         libmpi_ibm.so.3 =>
>> (0x0000200020ab0000)
>>         libpgf90rtl.so =>
>> (0x0000200020c20000)
>>         libpgf90.so =>
>> (0x0000200020c60000)
>>         libpgf90_rpm1.so =>
>> (0x0000200021210000)
>>         libpgf902.so =>
>> (0x0000200021240000)
>>         libpgftnrtl.so =>
>> (0x0000200021270000)
>>         libatomic.so.1 => /usr/lib64/libatomic.so.1 (0x00002000212a0000)
>>         libpgkomp.so =>
>> (0x00002000212d0000)
>>         libomp.so =>
>> (0x0000200021300000)
>>         libomptarget.so =>
>> (0x00002000213f0000)
>>         libpgmath.so =>
>> (0x0000200021420000)
>>         libpgc.so =>
>> (0x0000200021540000)
>>         librt.so.1 => /usr/lib64/librt.so.1 (0x00002000216b0000)
>>         libm.so.6 => /usr/lib64/libm.so.6 (0x00002000216e0000)
>>         libgcc_s.so.1 => /usr/lib64/libgcc_s.so.1 (0x00002000217d0000)
>>         libc.so.6 => /usr/lib64/libc.so.6 (0x0000200021810000)
>>         libz.so.1 =>
>> (0x0000200021a10000)
>>         libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x0000200021a60000)
>> /sw/summit/cuda/10.1.168/lib64/libcublasLt.so.10 (0x0000200021ab0000)
>>         libutil.so.1 => /usr/lib64/libutil.so.1 (0x00002000239c0000)
>> (0x00002000239f0000)
>> (0x0000200023a60000)
>> (0x0000200023ae0000)
>>         libopen-rte.so.3 =>
>> (0x0000200023b10000)
>>         libopen-pal.so.3 =>
>> (0x0000200023c20000)
>>         libXau.so.6 => /usr/lib64/libXau.so.6 (0x0000200023d10000)
>> On Feb 7, 2020, at 2:31 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>  ldd -o on the executable of both linkings of your code.
>>  My guess is that without PETSc it is linking the static version of the
>> needed libraries and with PETSc the shared. And, in typical fashion, the
>> shared libraries are off on some super slow file system so take a long time
>> to be loaded and linked in on demand.
>>   Still a performance bug in Summit.
>>   Barry
>> On Feb 7, 2020, at 12:23 PM, Zhang, Hong via petsc-dev <
>> Hi all,
>> Previously I have noticed that the first call to a CUDA function such as
>> cudaMalloc and cudaFree in PETSc takes a long time (7.5 seconds) on summit.
>> Then I prepared a simple example as attached to help OCLF reproduce the
>> problem. It turned out that the problem was  caused by PETSc. The
>> 7.5-second overhead can be observed only when the PETSc lib is linked. If I
>> do not link PETSc, it runs normally. Does anyone have any idea why this
>> happens and how to fix it?
>> Hong (Mr.)
>> bash-4.2$ cat ex_simple.c
>> #include <time.h>
>> #include <stdio.h>
>> double  cputime;
>> start = clock();
>> cudaFree(0);
>> s1 = clock();
>> s2 = clock();
>> s3 = clock();
>> printf("free time =%lf malloc time =%lf copy time =%lf\n",((double) (s1 -
>> return 0;
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200210/c826ca0e/attachment-0001.html>
