[petsc-dev] DMPlex + P_1 FE interpolation
Pierre Jolivet pierre.jolivet at enseeiht.fr
Mon Feb 10 07:17:54 CST 2020
> On 10 Feb 2020, at 1:08 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Feb 9, 2020 at 11:11 PM Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>> On 10 Feb 2020, at 6:20 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Sun, Feb 9, 2020 at 3:23 PM Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>> Hello,
>> I’ve a hard time answering the following DMPlex questions by just looking at some of the examples and manual.
>> Considering two DMPlex dm and dma, as in petsc/src/dm/impls/plex/examples/tests/ex19.c, I’d like to interpolate a simple P_1 FE function from dm to dma.
>> The DMCreateInterpolation call gives me:
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Number of fine indices 0 != 4 dual basis vecs
>> It looks like your fine grid has no discretization, since 0 is numFIndices from
>>   ierr = DMPlexGetClosureIndices(dmf, fsection, globalFSection, cell, &numFIndices, &findices, NULL);CHKERRQ(ierr);
>> [0]PETSC ERROR: #1 DMPlexComputeInterpolatorGeneral() line 2508 in petsc/src/dm/impls/plex/plexfem.c
>> [0]PETSC ERROR: #2 DMCreateInterpolation_Plex() line 7688 in petsc/src/dm/impls/plex/plex.c
>> [0]PETSC ERROR: #3 DMCreateInterpolation() line 1139 in petsc/src/dm/interface/dm.c
>> But the DMs look OK, don’t they, cf. below?
>> So I have three simple questions:
>> 1) are all tests at the bottom of ex19.c broken because of PRAgMaTIc or because of DMPlex currently not supporting some operations? (I’m not using PRAgMaTIc to do mesh adaptation, so I was hoping to not run into an error)
>> I don't think its broken.
> Oh, OK. Could you help me figure out what’s the problem then, e.g., with a slight (command line) variation of test #6, please?
> Sure. I am at SIAM this week, but as soon as I can I will get you the fix.
Excellent.
> $ cd src/dm/impls/plex/examples/tests
> $ git diff ex19.c
> $ make ex19
> $ mpirun ./ex19 -dim 3 -nbrVerEdge 10 -dm_plex_separate_marker 0 -met 0 -hmin 0.1 -hmax 0.3 -init_dm_view -adapt_dm_view -do_L2 -petscspace_degree 1 -petscfe_default_quadrature_order 1 -dm_plex_hash_location
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: The section point closure size 0 != dual space dimension 4
> [0]PETSC ERROR: #1 DMProjectLocal_Generic_Plex() line 633 in src/dm/impls/plex/plexproject.c
> [0]PETSC ERROR: #2 DMProjectFunctionLocal_Plex() line 771 in src/dm/impls/plex/plexproject.c
> [0]PETSC ERROR: #3 DMProjectFunctionLocal() line 7809 in src/dm/interface/dm.c
> [0]PETSC ERROR: #4 DMProjectFunction() line 7766 in src/dm/interface/dm.c
> If I comment the DMProjectFunction() call, I end up with the same error as in my first message in DMCreateInterpolation().
>> 2) is DMCreateInterpolation + MatInterpolate the correct way of transferring one Vec from a DMPlex onto another?
>> That is the intent.
>> 3) if yes, by looking at the names of the arguments in DMPlexComputeInterpolatorGeneral, dmc and dmf, could you comment on the performance of this function for unrelated meshes, e.g., if both DMs are “fine” and not one coarse and the other fine (albeit non-nested), for simple P_k spaces.
>> In general, it is going to be horrible. Here is what it does: locate the fine quadrature points in the coarse grid and interpolate to them. This quadrature can have huge errors if it falls across multiple cells. This is why the nested version works perfectly, and also why Patrick Farrell and James Maddison have the Supermesh library, which makes a refinement of the mesh until the quadrature is accurate everywhere. That way they guarantee that at least the zeroth moment is preserved.
> Two subquestions if I may:
> 1) are there any plans to have this integrated through an external package?
> In the absence of a plan, there is a hope. I would really like it to happen.
> 2) if I understand you correctly, you answered about the numerical performance of the function. I can live with high interpolation errors if both meshes are “far" from each other. I was mostly interested in the parallel performance of the function.
> Everything is purely local except for point location. Since it has never really been tested in this mode, I am sure the
> scaling can be bad. I believe the default is to extrapolate if the point is not covered, which makes sense for mostly
> matching meshes. There is parallel point location, but it is intended for a few points where we are sampling the solution,
> rather than lots of points everywhere which you would get for non-matching meshes with different distributions. Could
> you say what kind of situation you are trying to optimize for?
As a disclaimer, I’m not trying to optimize anything yet. Just assessing the potential benefits of using DMPlex.
We have many solvers using mesh adaptation, so I’ll give you just one specific example.
When doing shape optimization, e.g., http://www.cmap.polytechnique.fr/~florian.feppon/videos/04_08.webm <http://www.cmap.polytechnique.fr/~florian.feppon/videos/04_08.webm>, we redistribute an adapted mesh and reinterpolate a level-set.
The only missing piece to have something fully distributed, now that the mesh adaptation may be done in parallel, is the interpolator, we basically do (1) in Dave’s email.
It would probably not extremely hard to implement this better, but if I can leverage DMPlex to take care of mesh (re)distribution + solution interpolation, I’d prefer invest time in hooking this into our code instead of implementing the wheel.
Pierre
>   Thanks,
>     Matt
> Thanks,
> Pierre
>>   Thanks,
>>     Matt
>> Thanks in advance for your help,
>> Pierre
>> $ mpirun -n 1 ./ex19 -msh in.msh -init_dm_view ::ascii_info -adapt_dm_view ::ascii_info -mat_view ::ascii_info -do_L2 -petscspace_degree 1
>> DM Object: DMinit 1 MPI processes
>>   type: plex
>> DMinit in 3 dimensions:
>>   0-cells: 1331
>>   1-cells: 7930
>>   2-cells: 12600
>>   3-cells: 6000
>> Labels:
>>   depth: 4 strata with value/size (0 (1331), 1 (7930), 2 (12600), 3 (6000))
>>   Face Sets: 6 strata with value/size (4 (200), 1 (200), 5 (200), 2 (200), 3 (200), 6 (200))
>>   Cell Sets: 1 strata with value/size (0 (6000))
>> DM Object: DMadapt (adapt_) 1 MPI processes
>>   type: plex
>> DMadapt in 3 dimensions:
>>   0-cells: 2905
>>   1-cells: 18888
>>   2-cells: 31368
>>   3-cells: 15384
>> Labels:
>>   depth: 4 strata with value/size (0 (2905), 1 (18888), 2 (31368), 3 (15384))
>>   Face Sets: 6 strata with value/size (1 (200), 4 (200), 6 (200), 2 (200), 5 (200), 3 (200))
>>   Cell Sets: 1 strata with value/size (0 (15384))
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200210/6aee2ca9/attachment.html>
