[petsc-dev] DMPlex + P_1 FE interpolation
Matthew Knepley
knepley at gmail.com
Mon Feb 10 06:08:38 CST 2020
On Sun, Feb 9, 2020 at 11:11 PM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> On 10 Feb 2020, at 6:20 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Feb 9, 2020 at 3:23 PM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> wrote:
>> Hello,
>> I’ve a hard time answering the following DMPlex questions by just looking
>> at some of the examples and manual.
>> Considering two DMPlex dm and dma, as in
>> petsc/src/dm/impls/plex/examples/tests/ex19.c, I’d like to interpolate a
>> simple P_1 FE function from dm to dma.
>> The DMCreateInterpolation call gives me:
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Number of fine indices 0 != 4 dual basis vecs
> It looks like your fine grid has no discretization, since 0 is numFIndices
> from
> ierr = DMPlexGetClosureIndices(dmf, fsection, globalFSection, cell,
> &numFIndices, &findices, NULL);CHKERRQ(ierr);
>> [0]PETSC ERROR: #1 DMPlexComputeInterpolatorGeneral() line 2508 in
>> petsc/src/dm/impls/plex/plexfem.c
>> [0]PETSC ERROR: #2 DMCreateInterpolation_Plex() line 7688 in
>> petsc/src/dm/impls/plex/plex.c
>> [0]PETSC ERROR: #3 DMCreateInterpolation() line 1139 in
>> petsc/src/dm/interface/dm.c
>> But the DMs look OK, don’t they, cf. below?
>> So I have three simple questions:
>> 1) are all tests at the bottom of ex19.c broken because of PRAgMaTIc or
>> because of DMPlex currently not supporting some operations? (I’m not using
>> PRAgMaTIc to do mesh adaptation, so I was hoping to not run into an error)
> I don't think its broken.
> Oh, OK. Could you help me figure out what’s the problem then, e.g., with a
> slight (command line) variation of test #6, please?
Sure. I am at SIAM this week, but as soon as I can I will get you the fix.
> $ cd src/dm/impls/plex/examples/tests
> $ git diff ex19.c
> $ make ex19
> $ mpirun ./ex19 -dim 3 -nbrVerEdge 10 -dm_plex_separate_marker 0 -met 0
> -hmin 0.1 -hmax 0.3 -init_dm_view -adapt_dm_view -do_L2 -petscspace_degree
> 1 -petscfe_default_quadrature_order 1 -dm_plex_hash_location
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: The section point closure size 0 != dual space dimension 4
> [0]PETSC ERROR: #1 DMProjectLocal_Generic_Plex() line 633 in
> src/dm/impls/plex/plexproject.c
> [0]PETSC ERROR: #2 DMProjectFunctionLocal_Plex() line 771 in
> [0]PETSC ERROR: #3 DMProjectFunctionLocal() line 7809 in
> [0]PETSC ERROR: #4 DMProjectFunction() line 7766 in src/dm/interface/dm.c
> If I comment the DMProjectFunction() call, I end up with the same error as
> in my first message in DMCreateInterpolation().
> 2) is DMCreateInterpolation + MatInterpolate the correct way of
>> transferring one Vec from a DMPlex onto another?
> That is the intent.
>> 3) if yes, by looking at the names of the arguments in
>> DMPlexComputeInterpolatorGeneral, dmc and dmf, could you comment on the
>> performance of this function for unrelated meshes, e.g., if both DMs are
>> “fine” and not one coarse and the other fine (albeit non-nested), for
>> simple P_k spaces.
> In general, it is going to be horrible. Here is what it does: locate the
> fine quadrature points in the coarse grid and interpolate to them. This
> quadrature can have huge errors if it falls across multiple cells. This is
> why the nested version works perfectly, and also why Patrick Farrell and
> James Maddison have the Supermesh library, which makes a refinement of the
> mesh until the quadrature is accurate everywhere. That way they guarantee
> that at least the zeroth moment is preserved.
> Two subquestions if I may:
> 1) are there any plans to have this integrated through an external package?
In the absence of a plan, there is a hope. I would really like it to happen.
> 2) if I understand you correctly, you answered about the numerical
> performance of the function. I can live with high interpolation errors if
> both meshes are “far" from each other. I was mostly interested in the
> parallel performance of the function.
Everything is purely local except for point location. Since it has never
really been tested in this mode, I am sure the
scaling can be bad. I believe the default is to extrapolate if the point is
not covered, which makes sense for mostly
matching meshes. There is parallel point location, but it is intended for a
few points where we are sampling the solution,
rather than lots of points everywhere which you would get for non-matching
meshes with different distributions. Could
you say what kind of situation you are trying to optimize for?
Matt
> Thanks,
> Pierre
> Thanks,
> Matt
>> Thanks in advance for your help,
>> Pierre
>> $ mpirun -n 1 ./ex19 -msh in.msh -init_dm_view ::ascii_info
>> -adapt_dm_view ::ascii_info -mat_view ::ascii_info -do_L2
>> -petscspace_degree 1
>> DM Object: DMinit 1 MPI processes
>> type: plex
>> DMinit in 3 dimensions:
>> 0-cells: 1331
>> 1-cells: 7930
>> 2-cells: 12600
>> 3-cells: 6000
>> Labels:
>> depth: 4 strata with value/size (0 (1331), 1 (7930), 2 (12600), 3
>> (6000))
>> Face Sets: 6 strata with value/size (4 (200), 1 (200), 5 (200), 2
>> (200), 3 (200), 6 (200))
>> Cell Sets: 1 strata with value/size (0 (6000))
>> DM Object: DMadapt (adapt_) 1 MPI processes
>> type: plex
>> DMadapt in 3 dimensions:
>> 0-cells: 2905
>> 1-cells: 18888
>> 2-cells: 31368
>> 3-cells: 15384
>> Labels:
>> depth: 4 strata with value/size (0 (2905), 1 (18888), 2 (31368), 3
>> (15384))
>> Face Sets: 6 strata with value/size (1 (200), 4 (200), 6 (200), 2
>> (200), 5 (200), 3 (200))
>> Cell Sets: 1 strata with value/size (0 (15384))
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200210/e07a1555/attachment.html>
