[petsc-dev] is make alldoc tested?
Tue Feb 4 14:41:42 CST 2020
Don't know how we'll monitor scheduled tests. Unless there is an error in CI - issues that come up will be ignored as before.
perhaps we can add a smaller (subset of) doc build in CI.
Currently we have 20 odd stages in doc build targets - and errors in each stage are ignored. So will have to fix them to stop on error [in the subset of targets we build in CI]
And all doc-only changes would have to be run through this CI test - before merge..
Satish
On Tue, 4 Feb 2020, Smith, Barry F. via petsc-dev wrote:
>   Yikes, they should become gitlab CI tests, perhaps run by schedule at 2 in the morning each day or something and upload the results as artifacts.
>    Barry
> > On Feb 4, 2020, at 10:44 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > The doc builds are at http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/ - but not in gitlab-ci.
> > I have the fixes at https://gitlab.com/petsc/petsc/-/merge_requests/2503
> > Satish
> > On Sat, 1 Feb 2020, Smith, Barry F. via petsc-dev wrote:
> >> Generating manual example links
> >> Unexpected argument -printmatch-link!
> >> manualpages in: /Users/barrysmith/Src/petsc/src/snes/linesearch/impls/bt
> >> Error: Error reading html.def in path .:/Users/barrysmith/Src/petsc/arch-master/share or  TEXTFILTER_PATH environment variable:-1
> >> manualpages in: /Users/barrysmith/Src/petsc/src/snes/linesearch/impls/nleqerr
> >> manualpages_buildcite in: /Users/barrysmith/Src/petsc/src/mat/coarsen/ftn-custom
> >> gmake[5]: *** No rule to make target 'tree_basic'.  Stop.
> >> gmake[4]: [/Users/barrysmith/Src/petsc/lib/petsc/conf/rules:124: tree_basic] Error 2 (ignored)
> >> manualpages_buildcite in: /Users/barrysmith/Src/petsc/src/mat/order
> >> Maybe more
