[petsc-dev] ASM for each field solve on GPUs
Mark Adams mfadams at lbl.gov
Thu Dec 31 12:49:50 CST 2020
On Thu, Dec 31, 2020 at 1:12 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 31, 2020 at 12:46 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Still missing something:
> You can get in the debugger in PCFieldSplitSetDefaults(), but the most
> likely thing is that pc->dm == NULL here,
the setuponblocks PC does have a DM and it is a cusparse mattype.
> so the PC is not getting the DM.
> This does make some sense as you are doing ASM, which is ripping up the
> domain, so you might not want the same DM on the subproblem. I
> am not sure what should be done here.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201231/be6da075/attachment.html>
