[petsc-dev] ASM for each field solve on GPUs
Barry Smith
bsmith at petsc.dev
Wed Dec 30 18:09:48 CST 2020
If you are using direct solvers on each block on each GPU (several matrices on each GPU) you could pull apart, for example, MatSolve_SeqAIJCUSPARSE()
and launch each of the matrix solves on a separate stream. You could use a MatSolveBegin/MatSolveEnd style or as Jed may prefer a Wait() model. Maybe a couple hours coding to produce a prototype MatSolveBegin/MatSolveEnd from MatSolve_SeqAIJCUSPARSE.
Note pulling apart a non-coupled single MatAIJ that contains all the matrices would be hugely expensive. Better to build each matrix already separate or use MatNest with only diagonal matrices.
Barry
> On Dec 30, 2020, at 5:46 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
>> I see that ASM has a DM and can get subdomains from it. I have a DMForest
>> and I would like an ASM that has a subdomain for each field. How might I go
>> about doing this? (the fields are not coupled in the matrix so this would
>> give a block diagonal matrix, and thus exact with LU sub solvers.
> The fields are already not coupled or you want to filter the matrix and give back a single matrix with coupling removed?
> You can use Fieldsplit to get the math of field-based block Jacobi (or ASM, but overlap with fields tends to be expensive). Neither FieldSplit or ASM can run the (additive) solves concurrently (and most libraries would need something to drive the threads).
>> I am then going to want to get these separate solves to be run in parallel
>> on a GPU (I'm talking with Sherry about getting SuperLU working on these
>> small problems). In looking at PCApply_ASM it looks like this will take
>> some thought. KSPSolve would need to be non-blocking, etc., or a new apply
>> op might be needed.
>> Thanks,
>> Mark
