[petsc-dev] funny GPU timer data
    Mark Adams
    mfadams at lbl.gov
    Tue Dec 29 13:07:49 CST 2020
Ah yes the 10-100 merged.
And I am not calling the *GPU timers *so the Mflops is messed up.
And, I assume WaitForCUDA blocks on this MPI process's Cuda calls here. One
stream per process. This does not block with other MPI process Cuda calls.
  err  = WaitForCUDA();CHKERRCUDA(err);
*  ierr = PetscLogGpuTimeEnd();CHKERRQ(ierr);*  ierr =
PetscLogEventEnd(MAT_CUSPARSEGenerateTranspose,A,0,0,0);CHKERRQ(ierr);
On Tue, Dec 29, 2020 at 1:12 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Mark,
>     Aside from formatting are you sure there is an issue.   Could it be
> 100 % of the time and 100% of the flops and since there is not room for all
> the digits they end up sitting on top of each other?
>    Similarly could the flop rates be overlapped on top of each other?  You
> could try adding more digits in the print statement to make room for these
> values.
> *   Barry*
> On Dec 29, 2020, at 8:32 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I am seeing this from a GPU kernel.  The % flops is messed up and the flop
> rate does not look right:
> Event                Count      Time (sec)     Flop
>        --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   -
> GpuToCpu - GPU
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
>  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size
> Count   Size  %F
> Jac-kernel        13068 1.0 1.6106e+01 1.1 6.13e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00 *10100*  0  0  0  *10100*  0  0  0 *136983459*       0      0
> 0.00e+00    0 0.00e+00 100
> I use this in landau.cu:
>  ierr = PetscLogGpuFlops(flops*nip);CHKERRQ(ierr);
> Any idea what is going on here?
> Thanks,
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201229/41129c72/attachment.html>
