[petsc-dev] lovely error message
Barry Smith
bsmith at petsc.dev
Sat Dec 26 13:54:28 CST 2020
Thanks, this works. Should I make a MR to release with this addition? Otherwise how does release get built?
Barry
> On Dec 26, 2020, at 12:30 PM, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
> Although if you temporarily want to patch it in, just slap
> bibtex_bibfiles = ['../tex/petsc.bib','../tex/petscapp.bib’]
> Anywhere in conf.py
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
>> On Dec 26, 2020, at 12:27, Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
>> I looks like release does not yet have the fix from master (arguably the fix should have gone to release anyways…)
>> Best regards,
>>> On Dec 26, 2020, at 12:05, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>> I was trying to build the docs on release to reproduce the Pierre's "Documentation version mismatch?" petsc-dev email that came earlier.
>>> Does release no longer work with the Sphinx docs?
>>> Barry
>>>> On Dec 25, 2020, at 7:56 PM, Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
>>>> Barry,
>>>> What branch are you on? This should have been fixed by https://gitlab.com/petsc/petsc/-/merge_requests/3479 <https://gitlab.com/petsc/petsc/-/merge_requests/3479>, try rebasing over master.
>>>> Best regards,
>>>>> On Dec 25, 2020, at 19:43, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>> Yes, I must do something, but the error message gives no indication of how to do what needs to be done. We should hire these people to do the error message for PETSc.
>>>>> $ make sphinx-docs-all LOC=$PETSC_DIR
>>>>> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-release
>>>>> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-release --testdir=./arch-release/tests
>>>>> Running Sphinx v2.4.4
>>>>> Found DOT install: /usr/local/bin/dot
>>>>> loading pickled environment... failed
>>>>> failed: Can't get attribute 'BibfileCache' on <module 'sphinxcontrib.bibtex.cache' from '/Users/barrysmith/Src/petsc/arch-release/sphinx_docs_env/lib/python3.9/site-packages/sphinxcontrib/bibtex/cache.py'>
>>>>> Extension error:
>>>>> You must configure the bibtex_bibfiles setting
>>>>> gmake[2]: *** [Makefile:28: latexpdf] Error 1
>>>>> gmake[1]: *** [makefile:428: sphinx-docs-manual] Error 2
>>>>> make: *** [GNUmakefile:17: sphinx-docs-all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201226/dbacc352/attachment.html>
