[petsc-dev] lovely error message
Jacob Faibussowitsch
jacob.fai at gmail.com
Fri Dec 25 19:56:44 CST 2020
Barry,
What branch are you on? This should have been fixed by https://gitlab.com/petsc/petsc/-/merge_requests/3479 <https://gitlab.com/petsc/petsc/-/merge_requests/3479>, try rebasing over master.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Dec 25, 2020, at 19:43, Barry Smith <bsmith at petsc.dev> wrote:
> Yes, I must do something, but the error message gives no indication of how to do what needs to be done. We should hire these people to do the error message for PETSc.
> $ make sphinx-docs-all LOC=$PETSC_DIR
> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-release
> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-release --testdir=./arch-release/tests
> Running Sphinx v2.4.4
> Found DOT install: /usr/local/bin/dot
> loading pickled environment... failed
> failed: Can't get attribute 'BibfileCache' on <module 'sphinxcontrib.bibtex.cache' from '/Users/barrysmith/Src/petsc/arch-release/sphinx_docs_env/lib/python3.9/site-packages/sphinxcontrib/bibtex/cache.py'>
> Extension error:
> You must configure the bibtex_bibfiles setting
> gmake[2]: *** [Makefile:28: latexpdf] Error 1
> gmake[1]: *** [makefile:428: sphinx-docs-manual] Error 2
> make: *** [GNUmakefile:17: sphinx-docs-all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201225/11daf667/attachment.html>
