[petsc-dev] Build Fails And Warnings In KSP
    Barry Smith
    bsmith at petsc.dev
    Mon Dec 21 15:44:29 CST 2020
  There is a custom fortran stub but the C version does not have a /*@C
  I have also reported directly in the MR other broken things about the merge (MergeTrain is the way to go).
  Barry
> On Dec 21, 2020, at 3:40 PM, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Hm - this is from https://gitlab.com/petsc/petsc/-/merge_requests/3489
> Maybe I made a mistake in verifying the pipeline tests passing [before merging]
> Matt, Can you check on this? [or I can revert this merge]
> Satish
> On Mon, 21 Dec 2020, Jacob Faibussowitsch wrote:
>> Hello All,
>> Seems a recent change introduced the following errors (I have tried make clean, make allfortranstubs, and then rebuild):
>>     CLINKER master-arch-darwin-c-debug/lib/libpetsc.3.014.2.dylib
>> duplicate symbol '_kspconvergedrateview_' in:
>>    master-arch-darwin-c-debug/obj/ksp/ksp/interface/ftn-auto/itfuncf.o
>>    master-arch-darwin-c-debug/obj/ksp/ksp/interface/ftn-custom/zitfuncf.o
>> ld: 1 duplicate symbol for architecture x86_64
>> clang: error: linker command failed with exit code 1 (use -v to see invocation)
>> gmake[3]: *** [gmakefile:112: master-arch-darwin-c-debug/lib/libpetsc.3.014.2.dylib] Error 1
>> gmake[2]: *** [/Users/jacobfaibussowitsch/NoSync/petsc/lib/petsc/conf/rules:49: libs] Error 2
>> **************************ERROR*************************************
>>  Error during compile, check master-arch-darwin-c-debug/lib/petsc/conf/make.log
>>  Send it and master-arch-darwin-c-debug/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>
>> gmake[1]: *** [makefile:40: all] Error 1
>> gmake: *** [GNUmakefile:9: all] Error 2
>> And warnings (although they appear harmless):
>> src/ksp/ksp/interface/itfunc.c:2283:39: warning: passing 'PetscReal **' (aka 'double **') to parameter of type 'const PetscReal **' (aka 'const double **') discards qualifiers in nested pointer types [-Wincompatible-pointer-types-discards-qualifiers]
>>    ierr = KSPGetResidualHistory(ksp, &hist, &n);CHKERRQ(ierr);
>> src/ksp/ksp/interface/itfunc.c:2167:64: note: passing argument to parameter 'a' here
>> PetscErrorCode KSPGetResidualHistory(KSP ksp, const PetscReal *a[],PetscInt *na)
>> src/ksp/ksp/interface/itfunc.c:2306:36: warning: passing 'PetscReal **' (aka 'double **') to parameter of type 'const PetscReal **' (aka 'const double **') discards qualifiers in nested pointer types [-Wincompatible-pointer-types-discards-qualifiers]
>>    ierr = KSPGetErrorHistory(ksp, &hist, &n);CHKERRQ(ierr);
>> /Users/jacobfaibussowitsch/NoSync/petsc/src/ksp/ksp/interface/itfunc.c:2243:61: note: passing argument to parameter 'a' here
>> PetscErrorCode KSPGetErrorHistory(KSP ksp, const PetscReal *a[], PetscInt *na)
>> 2 warnings generated.
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>> Cell: (312) 694-3391
