[petsc-dev] this is INCORRECT make [-j <n>] -f share/petsc/examples/gmakefile test
Barry Smith
bsmith at petsc.dev
Mon Dec 21 11:51:41 CST 2020
Probably most of the gmakefile in that file should be gmakefile.test
Probably
To check if the libraries are working do:
make PETSC_DIR=<PETSC_DIR> PETSC_ARCH=<PETSC_ARCH> test
it is meant to be "check" here not test.
Page should also note that alltests does not work on --prefix installs?
arch-ci-linux-opt-misc.py uses --prefix how are the tests run for it in the CI? Does it use allgtests-tap, how? I cannot see how that particular job turns off testing? Or how it could locate allgtests-tap
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201221/7897476c/attachment.html>
