[petsc-dev] Building PETSc on LLNL Lassen
    Junchao Zhang
    junchao.zhang at gmail.com
    Sun Dec 13 18:32:13 CST 2020
Jacob,
  Do you need to add  'CUDAFLAGS=-ccbin xlc++' to specify the host compiler
for CUDA? Note in cuda.py I added
if self.compilers.cxxdialect in ['C++11','C++14']: #nvcc is a C++ compiler
so it is always good to add -std=xxx. It is even crucial when using thrust
complex (see MR 2822)
self.setCompilers.CUDAFLAGS += ' -std=' + self.compilers.cxxdialect.lower()
 In your configure.log, there are
#define PETSC_HAVE_CXX_DIALECT_CXX11 1
#define PETSC_HAVE_CXX_DIALECT_CXX14 1
I guess without -ccbin, nvcc uses gcc by default and your gcc does not
support C++14.
--Junchao Zhang
On Sun, Dec 13, 2020 at 1:25 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> Hello All,
> Does anyone have any experience building petsc with cuda support on
> Lassen? I’ve been having trouble building with ibm xl compilers +
> spectrum-mpi + nvcc. NVCC seems to not like -std=c++14 argument,
> complaining that its configured host compiler doesn’t support it, but
> compiling the following “test.cc":
> #include <stdlib.h>
> int main(int argc, char **argv)
>   int i = 1;
>   i += argc;
>   return(i);
> With mpicc -std=c++14 test.cc produces zero errors.
> Modules loaded:
> module load xl/2020.11.12-cuda-11.1.1
> module load spectrum-mpi
> module load cuda/11.1.1
> module load python/3.8.2
> module load cmake
> module load valgrind
> module load lapack
> My configure commands:
> ./configure  --with-cc=mpicc --with-cxx=mpiCC --with-fc=mpifort
> --with-cuda --with-debugging=1 PETSC_ARCH=arch-linux-c-debug
> The error:
> TESTING: findMPIInc from
> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:636)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Bad compiler flag:
> -I/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/include
> The actual configure.log error:
> Executing: nvcc -c -o
> /var/tmp/petsc-2v0k4k61/config.setCompilers/conftest.o
> -I/var/tmp/petsc-2v0k4\
> k61/config.setCompilers -I/var/tmp/petsc-2v0k4k61/config.types  -g
> -std=c++14 -I/usr/tce/packages/s\
> pectrum-mpi/ibm/spectrum-mpi-rolling-release/include  -Wno-deprecated-gpu-targets
> /var/tmp/petsc-2v\
> 0k4k61/config.setCompilers/conftest.cu
> Possible ERROR while running compiler:
> stderr:
> nvcc warning : The -std=c++14 flag is not supported with the configured
> host compiler. Flag will be\
>  ignored.
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> int main() {
>   return 0;
>                   Rejecting compiler flag
> -I/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/include  due
> to
> host compiler. Flag will be ignored.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201213/c58317f4/attachment.html>
