[petsc-dev] cusparse error
    Mark Adams
    mfadams at lbl.gov
    Wed Dec  9 20:09:32 CST 2020
OK, so I will remove my added init(). I guess you just retry the test.
On Wed, Dec 9, 2020 at 9:03 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Yes, these messages are because of lack of resources even though the
> error message says not initialized.
>   Barry
> On Dec 9, 2020, at 8:01 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Could be GPU resource competition. Note this test uses nsize=8.
> --Junchao Zhang
> On Wed, Dec 9, 2020 at 7:15 PM Mark Adams <mfadams at lbl.gov> wrote:
>> And this is a Cuda 11 complex build:
>> https://gitlab.com/petsc/petsc/-/jobs/901108135
>> On Wed, Dec 9, 2020 at 8:11 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> My MR is generating an error. Tee error message says cusparse has not
>>> been initialized, so I added a cuparse init, but I still get the error
>>> (appended, *adams/landau-gpu-assembly
>>> <https://gitlab.com/petsc/petsc/-/tree/adams/landau-gpu-assembly>*).
>>> Any ideas would be appreciated.
>>> I am trying to reproduce this on Summit and it fails with a timeout
>>> limit of 60s, but it only runs for a few seconds (see timers). Any ideas?
>>> 19:58 adams/landau-gpu-assembly= ~/petsc$ make -f gmakefile test
>>> search='ksp_ksp_tutorials-ex71_bddc_cusparse'
>>> PETSC_ARCH=arch-summit-opt-gnu-cuda
>>> Using MAKEFLAGS: PETSC_ARCH=arch-summit-opt-gnu-cuda
>>> search=ksp_ksp_tutorials-ex71_bddc_cusparse
>>>         TEST
>>> arch-summit-opt-gnu-cuda/tests/counts/ksp_ksp_tutorials-ex71_bddc_cusparse.counts
>>> not ok ksp_ksp_tutorials-ex71_bddc_cusparse # Exceeded timeout limit of
>>> 60 s
>>>  ok ksp_ksp_tutorials-ex71_bddc_cusparse # SKIP Command failed so no diff
>>> #   Summary
>>> # FAILED ksp_ksp_tutorials-ex71_bddc_cusparse
>>> # success 0/1 tests (0.0%)
>>> # failed 1/1 tests (100.0%)
>>> # todo 0/1 tests (0.0%)
>>> # skip 0/1 tests (0.0%)
>>> # Wall clock time for tests: 3 sec
>>> # Approximate CPU time (not incl. build time): 3.14 sec
>>> not ok ksp_ksp_tutorials-ex71_bddc_cusparse # Error code: 201
>>> 2391 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2391># [1]PETSC
>>> ERROR: --------------------- Error Message
>>> 2392 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2392># [1]PETSC
>>> ERROR: GPU error
>>> 2393 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2393># [1]PETSC
>>> ERROR: cuSPARSE error 1 (CUSPARSE_STATUS_NOT_INITIALIZED) : initialization
>>> error
>>> 2394 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2394># [1]PETSC
>>> ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for
>>> trouble shooting.
>>> 2395 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2395># [1]PETSC
>>> ERROR: Petsc Development GIT revision: v3.14.2-85-gd60087d GIT Date:
>>> 2020-12-09 17:49:59 -0500
>>> 2396 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2396># [1]PETSC
>>> ERROR: ../ex71 on a named frog by petsc Wed Dec 9 18:41:10 2020
>>> 2397 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2397># [1]PETSC
>>> ERROR: Configure options --package-prefix-hash=/home/petsc/petsc-hash-pkgs
>>> --with-make-test-np=2 COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g
>>> -O" --with-scalar-type=complex --with-precision=single
>>> --with-cuda-dir=/usr/local/cuda-11.0 PETSC_ARCH=arch-ci-linux-cuda11-complex
>>> 2398 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2398># [1]PETSC
>>> ERROR: #1 MatConvert_SeqAIJ_SeqAIJCUSPARSE() line 2708 in
>>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/src/mat/impls/aij/seq/seqcusparse/
>>> aijcusparse.cu
>>> 2399 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2399># [1]PETSC
>>> ERROR: #2 MatCreate_SeqAIJCUSPARSE() line 2739 in
>>> aijcusparse.cu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201209/ff7b38a3/attachment.html>
