[petsc-dev] MacOS firewall annoyance while running tests + solution
    Barry Smith
    bsmith at petsc.dev
    Fri Aug 28 21:39:58 CDT 2020
> On Aug 28, 2020, at 3:47 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Hapla  Vaclav" <vaclav.hapla at erdw.ethz.ch> writes:
>> On MacOS, maybe you also have lots of firewall popups appearing/disappearing when running tests like
>>  Do you want the application "ex29" to accept incoming network connections?
> Is there a way to express that the application does not need (should not accept) incoming connections?
  Yes, this also seems to work:
sudo $$FW --block $$APP
instead of
sudo $$FW --unblock $$APP
The parallel program still runs correctly to conclusion without the popup.
 When I run in the debugger the popup doesn't come up until after I pass the break point for listen.
 The program has an undocumented option -a <listen or accept> when you run with
sudo /usr/libexec/ApplicationFirewall/socketfilterfw -d -a accept
it prints ASKWHENACCEPT  which seems to indicate it will delay the popup until an accept is called but I can't confirm this because the debugger never stops in accept on one process but the popup still comes up so this argument may not work as I would expect.
There are strings in socketfilterfw
AKSWHENLISTEN
ASKWHENACCEPT
ASKWHENCONNECTOUT
TRUSTEDAPPS
LOCALONLYAPP
The local only app is intriguing
> Normalizing sudo during build/testing seems really bad.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200828/fe1f237e/attachment.html>
