[petsc-dev] MacOS firewall annoyance while running tests + solution
    Jed Brown
    jed at jedbrown.org
    Fri Aug 28 15:47:28 CDT 2020
"Hapla  Vaclav" <vaclav.hapla at erdw.ethz.ch> writes:
> On MacOS, maybe you also have lots of firewall popups appearing/disappearing when running tests like
>   Do you want the application "ex29" to accept incoming network connections?
Is there a way to express that the application does not need (should not accept) incoming connections?
Normalizing sudo during build/testing seems really bad.
