[petsc-dev] Pause-for-approval Pipelines?
    Satish Balay
    balay at mcs.anl.gov
    Thu Aug 27 12:17:47 CDT 2020
An improvement would be: disable the auto-start of the MR pipelines [and only enable 'Run pipeline' option on the 'pipeline tab']. But we don't know how to do this..
The current Pause-for-approval (in pre stage) is a away stop this auto-started MR pipeline - and 'continue' only if we need this test to complete.
Satish
On Thu, 27 Aug 2020, Stefano Zampini wrote:
> +1 for the new infrastructure
> > On Aug 27, 2020, at 6:59 PM, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > BTW: here are some reasons for using the MR pipeline instead of the web interface pipeline.
> > - it tests branch+master (more useful?) - instead of branch [web pipeline].
> > - you can skip the forced re-bases that were required when CI changed [i.e even if your branch is off old master - the latest CI settings from latest master will get used by MR pipeline]
> > - it enables testing of MRs from forks. [so the additional complexity of that workflow is now gone. Note: only developers can start these pipelines - from the pipeline tab on the MR web page]
> > And as mentioned - developers can ignore this, and continue to start pipelines from the web interface.
> > There is now some additional complexity in figuring out if the latest changes are tested [and by which pipeline, MR or web etc..] - but this part of the workflow should primarily affect integrator group.
> > Satish
> > On Thu, 27 Aug 2020, Satish Balay via petsc-dev wrote:
> >> On Thu, 27 Aug 2020, Jacob Faibussowitsch wrote:
> >>> Why does one pipeline request spawn two separate pipelines now? Specifically one is a normal pipeline whereas the other includes some sort of manual approval button which “runs” indefinitely if you don’t either cancel it or approve it.
> >> The 2 pipelines you see are
> >> - readdocs pipeline
> >> - merge-pipeline - auto starts - does the pre stage and pauses.
> >>> I think this was somewhat discussed in a previous MR (https://gitlab.com/petsc/petsc/-/merge_requests/3063 <https://gitlab.com/petsc/petsc/-/merge_requests/3063>) which indicates it is useful for doing a pipeline of the branch+destination but how is this different from the existing merge-train infrastructure that was already in place?
> >> Its not a replacement for merge train.[merge train is a way to do the merge when the MR is tested and ready for merge]
> >> However you can use this as a replacement for starting a new pipeline from the web interface https://gitlab.com/petsc/petsc/-/pipelines/new
> >> [i.e instead of starting a web interface pipeline - you just go to the MR page - 'pipeline tab' and hit continue]
> >> Or you can ignore this and continue to use the web interface.
> >>> It is annoying to have to manually go in and cancel the phony pipeline every time (not to mention twice as many emails from gitlab notifying me the femtosecond these pipelines fail).
> >> You shouldn't have to cancel the automatic MR pipeline. They should just stay paused.
> >> And I don't remember getting e-mails from these stalled MR pipelines. Perhaps you got them because of pre-stage failures?
> >> However if you have errors in pre stage tests - you might as well check and fix them.
> >> The one thats causing most trouble is readdocs pipeline. Its probably best to disable it until its issues are resolved.
> >> Satish
