[petsc-dev] Users manual update
Fande Kong
fdkong.jd at gmail.com
Mon Aug 24 12:22:11 CDT 2020
Could we support "make docs" instead of "xx-docs-xxx"?
Or were we planning to support multiple formats?
Fande,
On Fri, Aug 21, 2020 at 9:58 AM huabel via petsc-dev <petsc-dev at mcs.anl.gov>
wrote:
> success to make sphinx-docs-html.
> Thanks!
> On Aug 21, 2020, at 11:40 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> The updates referred in this thread are in master branch [and not maint]
> Satish
> On Fri, 21 Aug 2020, huabel via petsc-dev wrote:
> ➜ petsc git:(maint) make sphinx-docs-html
> /usr/local/opt/python at 3.8/bin/python3.8 ./config/gmakegen.py
> --petsc-arch=arch-darwin-c-debug
> /Volumes/data3/fun2/demox/petsc/config/gmakegentest.py
> --petsc-dir=/Volumes/data3/fun2/demox/petsc
> --petsc-arch=arch-darwin-c-debug --testdir=./arch-darwin-c-debug/tests
> gmake[1]: *** No rule to make target 'sphinx-docs-html'. Stop.
> gmake: *** [GNUmakefile:17: sphinx-docs-html] Error 2
> On Aug 21, 2020, at 11:06 PM, Jed Brown <jed at jedbrown.org> wrote:
> huabel via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> Thanks, I copied the ‘developer’ fold out and comment
> (#extensions.append('sphinxcontrib.bibtex’) this line, with few copy it
> works well, (no cite link), for me it enough.
> We recommend using `make sphinx-docs-html` from the top-level. It will
> create/activate a virtualenv based on requirements.txt so everything will
> work. It's fast for incremental updates.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200824/1dac3379/attachment.html>
