[petsc-dev] Users manual update
    huabel
    hu.ds.abel at icloud.com
    Fri Aug 21 10:18:40 CDT 2020
➜  petsc git:(maint) make sphinx-docs-html
/usr/local/opt/python at 3.8/bin/python3.8 ./config/gmakegen.py --petsc-arch=arch-darwin-c-debug
/usr/local/opt/python at 3.8/bin/python3.8 /Volumes/data3/fun2/demox/petsc/config/gmakegentest.py --petsc-dir=/Volumes/data3/fun2/demox/petsc --petsc-arch=arch-darwin-c-debug --testdir=./arch-darwin-c-debug/tests
gmake[1]: *** No rule to make target 'sphinx-docs-html'.  Stop.
gmake: *** [GNUmakefile:17: sphinx-docs-html] Error 2
> On Aug 21, 2020, at 11:06 PM, Jed Brown <jed at jedbrown.org> wrote:
> huabel via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> Thanks, I copied the ‘developer’ fold out and comment (#extensions.append('sphinxcontrib.bibtex’) this line, with few copy it works well, (no cite link), for me it enough.
> We recommend using `make sphinx-docs-html` from the top-level.  It will create/activate a virtualenv based on requirements.txt so everything will work.  It's fast for incremental updates.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200821/3cb2c33e/attachment.html>
