[petsc-dev] test harness failure make -f gmakefile.test test query='requires' queryval='kokkos'
Barry Smith
bsmith at petsc.dev
Tue Aug 11 21:11:20 CDT 2020
Scott,
Sometimes when I run the below test the harness mis-behaves. I cannot say what is different when this happens and doesn't because sometimes it also works.
Thanks
Barry
Traceback (most recent call last):
File "config/query_tests.py", line 226, in <module>
main()
File "config/query_tests.py", line 187, in main
petsc_full_arch = os.path.join(petsc_dir, petsc_arch)
File "/usr/lib64/python3.7/posixpath.py", line 94, in join
genericpath._check_arg_types('join', a, *p)
File "/usr/lib64/python3.7/genericpath.py", line 153, in _check_arg_types
(funcname, s.__class__.__name__)) from None
TypeError: join() argument must be str or bytes, not 'NoneType'
Using MAKEFLAGS: -- queryval=kokkos query=requires
# No tests run
# No tests run
# No tests run
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200811/7917894b/attachment.html>
