[petsc-dev] Configure --with-X-dir= Using Relative Path
Jacob Faibussowitsch
jacob.fai at gmail.com
Sun Aug 2 13:57:30 CDT 2020
Hello All,
I am reconfiguring an arch within a docker using the attached reconfigure script. My petsc dir is mounted via the following commands to docker -v ${PETSC_DIR}:/petsc:delegated. I am trying to use the existing arches on my native machine as the install directories for packages compiled within the docker images because SSH keys aren’t persistent in the images and hence git pull’s won’t work. I encountered this odd bug when trying —with-zlib-dir where it prepends the existing $PETSC_DIR to the directory name automatically, but this problem persists for any package.
There is no configure.log generated since this I guess is early enough in the configure process, so unfortunately the only error output is the wall of error text from terminal. The error indicates that configure is passing ./[COMMAND LINE DIRECTORY] instead of [COMMAND LINE DIRECTORY] to configure.
$ ls ${PETSC_DIR}/master-arch-darwin-c-debug/externalpackages/
Permissions Size User Date Modified Name
drwxrwxr-x - root 8 Jul 16:07 petsc-pkg-mumps-d1a5c931b762
drwxr-xr-x - root 3 Jul 21:39 hdf5-1.12.0
drwxrwxr-x - root 1 Aug 21:34 netcdf-c-4.5.0
drwxr-xr-x - root 3 Jul 21:38 zlib-1.2.11
drwxr-xr-x - root 29 Jul 17:43 mpich-3.3.2
drwxr-xr-x - root 6 Jul 17:06 Chaco-2.2-p2
drwxr-xr-x - root 1 Aug 21:36 git.ctetgen
drwxr-xr-x - root 1 Aug 21:34 git.exodusii
drwxr-xr-x - root 1 Aug 21:31 git.med
drwxr-xr-x - root 1 Aug 21:31 git.metis
drwxr-xr-x - root 1 Aug 21:31 git.parmetis
drwxr-xr-x - root 1 Aug 21:32 git.pnetcdf
drwxr-xr-x - root 1 Aug 21:35 git.scalapack
drwxr-xr-x - root 1 Aug 21:31 git.sowing
drwxr-xr-x - root 1 Aug 21:34 git.triangle
$ echo $PETSC_DIR
/petsc
$./reconfigure-arch-linux-c-debug
Configuring PETSc to compile on your system
TypeError or ValueError possibly related to ERROR in COMMAND LINE ARGUMENT while running ./configure
Nonexistent directory: /petsc/${PETSC_DIR}/master-arch-darwin-c-debug/externalpackages/zlib-1.2.11 for key with-zlib-dir
File "/petsc/config/configure.py", line 449, in petsc_configure
framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:], loadArgDB = 0)
File "/petsc/config/BuildSystem/config/framework.py", line 107, in __init__
self.createChildren()
File "/petsc/config/BuildSystem/config/framework.py", line 324, in createChildren
self.getChild(moduleName)
File "/petsc/config/BuildSystem/config/framework.py", line 309, in getChild
config.setupDependencies(self)
File "/petsc/config/PETSc/Configure.py", line 91, in setupDependencies
obj = self.registerPythonFile(package,'config.packages')
File "/petsc/config/PETSc/Configure.py", line 49, in registerPythonFile
utilityObj = self.framework.require(directory+utilityName, self)
File "/petsc/config/BuildSystem/config/framework.py", line 329, in require
config = self.getChild(moduleName, keywordArgs)
File "/petsc/config/BuildSystem/config/packages/ADIOS.py", line 17, in setupDependencies
self.zlib = framework.require('config.packages.zlib',self)
File "/petsc/config/BuildSystem/config/framework.py", line 307, in getChild
config.setup()
File "/petsc/config/BuildSystem/config/base.py", line 94, in setup
script.Script.setup(self)
File "/petsc/config/BuildSystem/script.py", line 108, in setup
logger.Logger.setup(self)
File "/petsc/config/BuildSystem/logger.py", line 75, in setup
args.ArgumentProcessor.setup(self)
File "/petsc/config/BuildSystem/args.py", line 76, in setup
self.setupArguments(self.argDB)
File "/petsc/config/BuildSystem/script.py", line 92, in setupArguments
self.setupHelp(self.help)
File "/petsc/config/BuildSystem/config/packages/zlib.py", line 16, in setupHelp
config.package.Package.setupHelp(self, help)
File "/petsc/config/BuildSystem/config/package.py", line 156, in setupHelp
help.addArgument(self.PACKAGE,'-with-'+self.package+'-dir=<dir>',nargs.ArgDir(None,None,'Indicate the root directory of the '+self.name+' installation',mustExist = 1))
File "/petsc/config/BuildSystem/help.py", line 108, in addArgument
self.argDB.setType(self.getArgName(name), argType, forceLocal = 1)
File "/petsc/config/BuildSystem/RDict.py", line 222, in setType
value.setValue(v.getValue())
File "/petsc/config/BuildSystem/nargs.py", line 325, in setValue
raise ValueError('Nonexistent directory: '+str(value)+' for key '+str(self.key))
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200802/27dd8b94/attachment.html>
Type: text/x-python-script
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200802/27dd8b94/attachment.bin>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200802/27dd8b94/attachment-0001.html>
