[petsc-dev] fix conflict between triangle and spai
    Satish Balay
    balay at mcs.anl.gov
    Thu Apr 30 11:20:31 CDT 2020
I was testing this with branch balay/test in both triangle repo and petsc repo
If you are to work on this - I guess I should rename them more appropriately.
Ok - for now will leave balay/test  in triangle [eventually this should become master when we switch]
And I created balay/triangle-1.6 branch in petsc [will have to rebase this - once balay/gfortran-10-fixes/maint gets merged in.]
thanks,
Satish
On Thu, 30 Apr 2020, Matthew Knepley wrote:
> What branch should I make fixes in?
>   Thanks,
>     Matt
> On Thu, Apr 30, 2020 at 11:18 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > I've attempted a build with master [aka triangle-1.6] - there was a fix I
> > had to add to triangle to compile.
> > When I run CI - many petsc examples give diffs. Likely triangle-1.6 was
> > never tested with petsc.
> > https://gitlab.com/petsc/petsc/pipelines/140824859
> > So won't make this change now.
> > Satish
> > On Tue, 28 Apr 2020, Matthew Knepley wrote:
> > > On Tue, Apr 28, 2020 at 10:23 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > And I see:
> > > > $ git branch -r
> > > >   origin/HEAD -> origin/master
> > > >   origin/maint-1.3
> > > >   origin/master
> > > > master has triangle-1.6 changes. However petsc is installing and using
> > > > triangle-1.3 i.e maint.
> > > > Matt - any idea why this discrepancy?
> > > I have no idea. It should not be doing that.
> > > That change looks fine to me.
> > >   Thanks,
> > >      Matt
> > > > Satish
> > > > On Tue, 28 Apr 2020, Satish Balay via petsc-dev wrote:
> > > > > I get the following error with triangle+spai build with gcc-10 [this
> > is
> > > > on linux though - ignore osx in PETSC_ARCH]
> > > > >      CLINKER arch-ci-osx-cxx-pkgs-opt/lib/libpetsc.so.3.13.0
> > > > > /usr/bin/ld:
> > /home/balay/petsc/arch-ci-osx-cxx-pkgs-opt/lib/libtriangle.a(triangle.o):/home/balay/petsc/arch-ci-osx-cxx-pkgs-opt/externalpackages/Triangle/src/triangle.c:667:
> > > > multiple definition of `epsilon';
> > /home/balay/petsc/arch-ci-osx-cxx-pkgs-opt/lib/libspai.a(spai.o):(.bss+0x188):
> > > > first defined here
> > > > > Matt,
> > > > > Any objection to this change to triangle?
> > > > > diff --git a/src/triangle.c b/src/triangle.c
> > > > > index 8e915a1..76f6d84 100644
> > > > > --- a/src/triangle.c
> > > > > +++ b/src/triangle.c
> > > > > @@ -664,7 +664,7 @@ long samples;                /* Number of random
> > > > samples for point location. */
> > > > >  unsigned long randomseed;                     /* Current random
> > number
> > > > seed. */
> > > > >  REAL splitter;       /* Used to split REAL factors for exact
> > > > multiplication. */
> > > > > -REAL epsilon;                             /* Floating-point machine
> > > > epsilon. */
> > > > > +static REAL epsilon;                      /* Floating-point machine
> > > > epsilon. */
> > > > >  REAL resulterrbound;
> > > > >  REAL ccwerrboundA, ccwerrboundB, ccwerrboundC;
> > > > >  REAL iccerrboundA, iccerrboundB, iccerrboundC;
> > > > > Satish
