[petsc-dev] fix conflict between triangle and spai
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 28 09:43:02 CDT 2020
On Tue, Apr 28, 2020 at 10:23 AM Satish Balay <balay at mcs.anl.gov> wrote:
> And I see:
> $ git branch -r
>   origin/HEAD -> origin/master
>   origin/maint-1.3
>   origin/master
> master has triangle-1.6 changes. However petsc is installing and using
> triangle-1.3 i.e maint.
> Matt - any idea why this discrepancy?
I have no idea. It should not be doing that.
That change looks fine to me.
     Matt
> Satish
> On Tue, 28 Apr 2020, Satish Balay via petsc-dev wrote:
> > I get the following error with triangle+spai build with gcc-10 [this is
> on linux though - ignore osx in PETSC_ARCH]
> >      CLINKER arch-ci-osx-cxx-pkgs-opt/lib/libpetsc.so.3.13.0
> > /usr/bin/ld:
> /home/balay/petsc/arch-ci-osx-cxx-pkgs-opt/lib/libtriangle.a(triangle.o):/home/balay/petsc/arch-ci-osx-cxx-pkgs-opt/externalpackages/Triangle/src/triangle.c:667:
> multiple definition of `epsilon';
> /home/balay/petsc/arch-ci-osx-cxx-pkgs-opt/lib/libspai.a(spai.o):(.bss+0x188):
> first defined here
> > Matt,
> > Any objection to this change to triangle?
> > diff --git a/src/triangle.c b/src/triangle.c
> > index 8e915a1..76f6d84 100644
> > --- a/src/triangle.c
> > +++ b/src/triangle.c
> > @@ -664,7 +664,7 @@ long samples;                /* Number of random
> samples for point location. */
> >  unsigned long randomseed;                     /* Current random number
> seed. */
> >  REAL splitter;       /* Used to split REAL factors for exact
> multiplication. */
> > -REAL epsilon;                             /* Floating-point machine
> epsilon. */
> > +static REAL epsilon;                      /* Floating-point machine
> epsilon. */
> >  REAL resulterrbound;
> >  REAL ccwerrboundA, ccwerrboundB, ccwerrboundC;
> >  REAL iccerrboundA, iccerrboundB, iccerrboundC;
> > Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200428/9b047d24/attachment.html>
