[petsc-dev] MATOP_MAT_MULT
Pierre Jolivet pierre.jolivet at enseeiht.fr
Sat Apr 25 11:45:15 CDT 2020
Hong,
José didn’t report this, though he may have run into the same issue, I did.
I’ll try the branch and get back at you on GitLab MR.
Pierre
> On 25 Apr 2020, at 6:17 PM, Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Jose,
> >> I also now just tested some previously PETSC_VERSION_LT(3,13,0) running code with C=A*B, Dense=Nest*Dense, all previously allocated prior to a call to MatMatMult and scall = MAT_REUSE_MATRIX.
> >> Sadly, it’s now broken. It is my fault for not having a test for this in https://gitlab.com/petsc/petsc/-/merge_requests/2069 <https://gitlab.com/petsc/petsc/-/merge_requests/2069>, sorry about that.
> >> [0]PETSC ERROR: Call MatProductSymbolic() first
> >> [0]PETSC ERROR: #1 MatProductNumeric() line 730 in /ccc/work/cont003/rndm/rndm/petsc/src/mat/interface/matproduct.c
> >> [0]PETSC ERROR: #2 MatMatMult() line 9335 in /ccc/work/cont003/rndm/rndm/petsc/src/mat/interface/matrix.c
> >> Here is a reproducer (that will work OK with 3.12.4).
> >> diff --git a/src/mat/tests/ex195.c b/src/mat/tests/ex195.c
> >> index c72662bc3c..811de669c5 100644
> >> --- a/src/mat/tests/ex195.c
> >> +++ b/src/mat/tests/ex195.c
> >> @@ -73,2 +73,3 @@ int main(int argc,char **args)
> >>    ierr = MatMatMult(nest,B,MAT_REUSE_MATRIX,PETSC_DEFAULT,&C);CHKERRQ(ierr);
> >> +  ierr = MatMatMult(nest,C,MAT_REUSE_MATRIX,PETSC_DEFAULT,&B);CHKERRQ(ierr);
> >>    ierr = MatMatMultEqual(nest,B,C,10,&equal);CHKERRQ(ierr);
> >> $ make -f gmakefile test searchin=mat_tests-ex195
> >> I believe this is very close to the topic at hand and issue #608, so maybe you could fix this as well in the same upcoming MR? Just let me know, I can have a crack it otherwise.
> This is a bug. I fixed it in the branch hzhang/fix-matproduct-reuse/maint. Can you test it?
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200425/9cb4f843/attachment-0001.html>
