[petsc-dev] Should PetscSignalHandlerDefault avoid calling MPI_Abort?
Junchao Zhang junchao.zhang at gmail.com
Tue Apr 21 22:09:45 CDT 2020
  I don't see problems calling _exit in PetscSignalHandlerDefault. Let me
try it first.
--Junchao Zhang
On Tue, Apr 21, 2020 at 3:17 PM John Peterson <jwpeterson at gmail.com> wrote:
> Hi,
> I started a thread on discuss at mpich.org regarding some hanging canceled
> jobs that we were seeing:
> https://lists.mpich.org/pipermail/discuss/2020-April/005910.html
> It turns out that there are some fairly strict rules about what types of
> functions (asynchronous-safe only) can be called from signal handlers, and
> MPI_Abort(), at least the mpich implementation of it, apparently does not
> fall into that category. I wonder if you have any comments on this. One
> possibility might be might be to just call "_exit" from
> PetscSignalHandlerDefault rather than PETSCABORT, not sure what other
> issues that would cause, however.
> Thanks,
> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200421/dbd68e58/attachment.html>
