[petsc-dev] Modify 3rd party lib
    Mark Adams
    mfadams at lbl.gov
    Tue Apr 21 06:12:42 CDT 2020
On Mon, Apr 20, 2020 at 10:28 PM Xiaoye S. Li <xsli at lbl.gov> wrote:
> Mark,
> thanks for debugging this!  Indeed, I confirm -- that particular "free"
> should be regular free instead of cudaHostfree(), because that data
> structure is not allocated by cudaAllocHost().  I have been running this
> cuda code on Summit, somehow the bug didn't show up.
Odd, but it seems to work fine for me now. eg, I get a speedup of 6x on a
~50K equation 3D systems (Q3 elements with 2 dof per vertex).
> I just updated the master branch with this fix.  Will be absorbed in a
> future release.
> As for PRNTlevel>=2, perhaps check your cmake build script.  It should be
> set to 0 for production build.
I don't see where that gets set. PRNTlevel does not seem to be in our repo.
I see it in 'MAKE_INC/make.cuda_gpu:         -DDEBUGlevel=0 -DPRNTlevel=1
-DPROFlevel=0', but I think it is set at >= 2. I have manually disabled the
print statements (~ 5 places).
> Sherry
> On Sun, Apr 19, 2020 at 6:32 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Also, we have PRNTlevel>=2 in SuperLU_dist. This is causing a lot of
>> output. It's not clear where that is set (it's a #define)
>> On Sun, Apr 19, 2020 at 9:28 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Sherry, I found the problem.
>>> I added this print statement to dDestroy_LU
>>>     nb = CEILING(nsupers, grid->npcol);
>>>     for (i = 0; i < nb; ++i)
>>> if ( Llu->Lrowind_bc_ptr[i] ) {
>>> *  fprintf(stderr,"dDestroy_LU: GPU free Llu->Lnzval_bc_ptr[%d/%d] = %p,
>>> CPU free Llu->Lrowind_bc_ptr =
>>> %p\n",i,nb,Llu->Lnzval_bc_ptr[i],Llu->Lrowind_bc_ptr[i]);*
>>>  SUPERLU_FREE (Llu->Lrowind_bc_ptr[i]);
>>> #ifdef GPU_ACC
>>>    checkCuda(cudaFreeHost(Llu->Lnzval_bc_ptr[i]));
>>> #else
>>>    SUPERLU_FREE (Llu->Lnzval_bc_ptr[i]);
>>> #endif
>>> And I see:
>>>    1 SNES Function norm 1.245977692562e-04
>>> *dDestroy_LU: GPU free Llu->Lnzval_bc_ptr[0/134] = 0x4ff9b000, CPU free
>>> Llu->Lrowind_bc_ptr = 0x4ff9a000*ex112d: cudahook.cc:762: CUresult
>>> host_free_callback(void*): Assertion `cacheNode != __null' failed.
>>> THis looks like Lnzval_bc_ptr is on the CPU so I removed the GPU_ACC
>>> stuff and it works now.
>>> I see this in distribution. Perhaps this a serial run bug?
>>> On Sun, Apr 19, 2020 at 5:58 PM Xiaoye S. Li <xsli at lbl.gov> wrote:
>>>> Mark,
>>>> you should fork a branch of your own to do this.
>>>> Sherry
>>>> On Sun, Apr 19, 2020 at 2:54 PM Stefano Zampini <
>>>> stefano.zampini at gmail.com> wrote:
>>>>> First, commit your changes to the superlu_dist branch, then rerun
>>>>> configure with
>>>>> —download-superlu_dist-commit=HEAD
>>>>> > On Apr 20, 2020, at 12:50 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> > I would like to modify SuperLU_dist but if I change the source and
>>>>> configure it says no need to reconfigure, use --force. I use --force and it
>>>>> seems to clobber my changes. Can I tell configure to use build but not
>>>>> download SuperLU?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200421/bf6ee059/attachment.html>
