[petsc-dev] Configure won't find python
    Satish Balay
    balay at mcs.anl.gov
    Sat Apr 18 11:23:38 CDT 2020
On Sat, 18 Apr 2020, Satish Balay via petsc-dev wrote:
> On Sat, 18 Apr 2020, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > >> > > Sure - the initial premise of this thread [as I understood] was: /usr/bin/python is python2. On python3 only installs - there is no /usr/bin/python (for ex: jedbrown/mpich-ccache docker file) - so we need to fix this issue in configure.
> > >> > > I'm guessing that most installs will have  /usr/bin/python as python2 or python3 - so missing /usr/bin/python is a smaller problem. Its not clear to me why this is missing in jedbrown/mpich-ccache - and how many OSes or distro will default to this mode.
> > >> > On Debian and Ubuntu, /usr/bin/python is part of python2; it isn't created if you `apt install python3`.
> > >> Ok - that a large userbase.
> > >> So when python2 deprecated in debian - there won't be /usr/bin/python anymore?
> > > Also - debian does alternatives - don't know if they can setup a default python [python2 vs python3] through this mechanism - and have anyone installed as default.
> > > [for ex: I think if openmpi is installed /usr/bin/mpicc is automatically setup as default via /etc/alternatives. I don't know if the same happens for mpich]
> > Alternatives is meant for compatible implementations.  Python2 and Python3 are not, so I doubt they will ever do that.
> > This indicates that /usr/bin/python will not exist in the next release.
> > https://wiki.debian.org/Python/2Removal
> > I don't know what exactly that means.  I'd guess it means one will need
> > to use backports to get python2 if one really needs it; even so, I don't
> > know if /usr/bin/python will exist.  Perhaps only /usr/bin/python2.
> > I don't know if they'll reintroduce /usr/bin/python at some release well
> > in the future, but we should expect for it to not exist for a while.
> The above URL is about packaging guidelines. i.e the packages in the distro should correctly use python2 or python3 dependencies.
> I don't see a mention of /usr/bin/python will be. [so yes - so we don't know what it will be - when python3 becomes the default]
> But until then - I don't consider missing /usr/bin/python a transition. jedbrown/mpich-ccache would be an example of user willfully not installing the default system python. (similar to not installing system default compilers). So don't think its a case of configure bug of not handling proper installs. [sure we have work-around for buggy compilers and some buggy installs so any support for missing /usr/bin/python  would be on that side].
> I wonder what python folk recommendation here is wrt dual use scripts..
The OSes that already migrated to python3 as default [Fedora - that I use, Arch? that Jed uses] do provide /usr/bin/python - which is python3.
So - hopefully Debian/Ubuntu will stick to this trend [assuming they haven't yet switched the default].
Satish
