[petsc-dev] Will DMPlexDistribute only ever distribute Cells?
Thu Apr 16 20:56:28 CDT 2020
On Thu, Apr 16, 2020 at 9:51 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> This algorithm does not work for any stratum
> Shouldn’t it? The IS generated are local to global conversions. Here is my
> current approach.
> Each Iocal IS will have local indices [0, 4) but the *value* of the index
> will be the global ID of the vertex, e.g. for 2 quads in a line (assuming
> as usual lowest rank owns points):
> 0——1——2
> |    P0 |  P1 |
> 3——4——5
> *VERTICES:*
> IS Object: 2 MPI processes
>   type: general
> [0] Number of indices in set 4
> [0] 0 0
> [0] 1 1
> [0] 2 3
> [0] 3 4
> [1] Number of indices in set 4
> [1] 0 -1
> [1] 1 2
> [1] 2 -4
> [1] 3 5
> So for total number of vertices the algorithm is:
> 1. Find max local IS value
> 2. Add 1 to it
> 3. All_reduce to proc 0
> 4. Find max of all_reduced values
The code that calculates the L2G _already_ computed the global size, it
just did not put it anywhere. If you are willing
to compute the L2G, you have already done what you want.
  Matt
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> On Apr 16, 2020, at 8:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Apr 16, 2020 at 9:28 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> What do you want to do?
>> Count the global number of points per depth based on all_reduce’ing the
>> maximum positive value returned from the IS’s listed below. This works as
>> intended for anything but cells since global number of points = max(IS) +
>> 1. For cells this breaks since 1 rank reports 3 as max, the next reports 6,
>> etc.
> I do not understand this at all. This algorithm does not work for any
> stratum. For example, suppose that we have a straight line of quad cells,
> 1 per process. The vertices would be [1, 5) on all processes but there
> would be 2*(P + 1) vertices.
>   Thanks,
>      Matt
>>  The system should be flexible enough to distribute whatever you want
>> What is the best way to check that a non-standard distribute has been
>> done?
>> Best regards,
>> On Apr 16, 2020, at 8:17 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Apr 16, 2020 at 9:04 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> Hello All,
>>> TL;DR: Is it possible now, or is it a planned feature, for plex to
>>> distribute over anything but points with height = 0?
>>> If I understand this correctly when plex currently partitions a graph,
>>> points with height 0 are only owned by a single process, but all other
>>> points can be co-owned by multiple procs.  For example for a 2D plex with 8
>>> vertices, 12 edges, and 6 cells over 2 procs these are the global-local
>>> IS’s for all points on processes (negative values indicate ownership by
>>> another proc) the final IS corresponding to cells will always have positive
>>> values as each proc is the sole owner of its cells.
>> What do you want to do? The system should be flexible enough to
>> distribute whatever you want, but the current guarantee
>> is that the cone of any points is always available. So if you decide to
>> distribute something else, like faces, then it ends up
>> looking just like an overlapping mesh with some custom overlap. Moreover,
>> the dual mesh only really makes sense for cells.
>> For faces/edges you would need a hypergraph partitioner.
>>   Thanks,
>>      Matt
>>> *VERTICES*
>>>   type: general
>>> [0] Number of indices in set 7
>>> [0] 0 -2
>>> [0] 1 0
>>> [0] 2 -3
>>> [0] 3 -4
>>> [0] 4 -5
>>> [0] 5 -6
>>> [0] 6 -8
>>> [1] Number of indices in set 7
>>> [1] 0 1
>>> [1] 1 2
>>> [1] 2 3
>>> [1] 3 4
>>> [1] 4 5
>>> [1] 5 6
>>> [1] 6 7
>>> *EDGES*
>>>   type: general
>>> [0] Number of indices in set 9
>>> [0] 0 0
>>> [0] 1 1
>>> [0] 2 -4
>>> [0] 3 -5
>>> [0] 4 -6
>>> [0] 5 2
>>> [0] 6 -7
>>> [0] 7 -9
>>> [0] 8 -11
>>> [1] Number of indices in set 9
>>> [1] 0 3
>>> [1] 1 4
>>> [1] 2 5
>>> [1] 3 6
>>> [1] 4 7
>>> [1] 5 8
>>> [1] 6 9
>>> [1] 7 10
>>> [1] 8 11
>>> *CELLS*
>>>   type: general
>>> [0] Number of indices in set 3
>>> [0] 0 0
>>> [0] 1 1
>>> [0] 2 2
>>> [1] Number of indices in set 3
>>> [1] 0 3
>>> [1] 1 4
>>> [1] 2 5
>>> Best regards,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200416/76edea8e/attachment-0001.html>
