[petsc-dev] DMPlexInterpolate after DMPlexDistribute
Tue Apr 14 07:36:03 CDT 2020
On Tue, Apr 14, 2020 at 6:36 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> I’d like to call DMPlexInterpolate after DMPlexDistribute and not the
> other way around for performance reasons (please stop me here if this is
> equivalent).
> When there is no overlap in DMPlexDistribute, it goes through fine.
> If there is overlap, I run into an error.
> Is this the expected behavior?
Yes. What we want you to do is:
1) Load/generate mesh
2) Distribute (this can be done at the same time as load with parallel load)
3) Interpolate (this is also an option from parallel load)
4) If necessary, redistribute for load balance
5) Construct overlap
    When you pass '1' below to DMDistribute(), it distributes as normal and
then calls
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexDistributeOverlap.html
    at the end. So you just postpone calling that until you have
interpolated.
    Matt
> Here is a MWE.
> $ patch -p1 < patch.txt
> $ cd src/dm/impls/plex/tests/
> $ make ex18
> $ mpirun -n 2 ./ex18 -distribute -interpolate after_distribute
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Point SF contains 1 which is a cell
> Thanks,
> Pierre
> diff --git a/src/dm/impls/plex/tests/ex18.c
> b/src/dm/impls/plex/tests/ex18.c
> index 07421b3522..dd62be58e5 100644
> --- a/src/dm/impls/plex/tests/ex18.c
> +++ b/src/dm/impls/plex/tests/ex18.c
> @@ -806 +806 @@ static PetscErrorCode CreateMesh(MPI_Comm comm, AppCtx
> *user, DM *dm)
> -    ierr = DMPlexDistribute(*dm, 0, NULL, &pdm);CHKERRQ(ierr);
> +    ierr = DMPlexDistribute(*dm, 1, NULL, &pdm);CHKERRQ(ierr);
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200414/90f907cb/attachment.html>
