[petsc-dev] CUDA + OMP make error
    Junchao Zhang
    junchao.zhang at gmail.com
    Mon Apr 13 18:08:19 CDT 2020
Probably matrix assembly on GPU is more important. Do you have an example
for me to play to see what GPU interface we should have?
--Junchao Zhang
On Mon, Apr 13, 2020 at 5:44 PM Mark Adams <mfadams at lbl.gov> wrote:
> I was looking into assembling matrices with threads. I have a coloring to
> avoid conflicts.
> Turning off all the logging seems way overkill and for methods that can
> get called in a thread then we could use PETSC_HAVE_THREADSAFTEY (thingy)
> to protect logging functions. So one can still get timings for the whole
> assembly process, just not for MatSetValues. Few people are going to do
> this. I don't think it will be a time sink, and if it is we just revert
> back to saying 'turn logging off'. I don't see a good argument for
> insisting on turning off logging, it is pretty important, if we just say
> that we are going to protect methods as needed.
> It is not a big deal, I am just exploring this idea. It is such a basic
> concept in shared memory sparse linear algebra that it seems like a good
> thing to be able to support and have in an example to say we can assemble
> matrices in threads (not that it is a great idea). We have all the tools
> (eg, coloring methods) that it is just a matter of protecting code a few
> methods. I use DMPlex MatClosure instead of MatSetValues and this is where
> I die now with non-thread safe code. We have an idea, from Jed, on how to
> fix it.
> Anyway, thanks for your help, but I think we should hold off on doing
> anything until we have some consensus that this would be a good idea to put
> some effort into getting a thread safe PETSc that can support OMP matrix
> assembly with a nice compact example.
> Thanks again,
> Mark
> On Mon, Apr 13, 2020 at 5:44 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Mark,
>>  I saw you had "--with-threadsaftey --with-log=0".  Do you really want to
>> call petsc from multiple threads (in contrast to letting petsc call
>> other libraries, e.g., BLAS, doing multithreading)?  If not, you can
>> drop --with-threadsaftey.
>>  I have https://gitlab.com/petsc/petsc/-/merge_requests/2714 that should
>> fix your original compilation errors.
>> --Junchao Zhang
>> On Mon, Apr 13, 2020 at 2:07 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> https://www.mcs.anl.gov/petsc/miscellaneous/petscthreads.html
>>> and I see this on my Mac:
>>> 14:23 1 mark/feature-xgc-interface-rebase *= ~/Codes/petsc$
>>> ../arch-macosx-gnu-O-omp.py
>>>              Configuring PETSc to compile on your system
>>>                Warning: PETSC_ARCH from environment does not match
>>> command-line or name of script.
>>>                                      Warning: Using from command-line or
>>> name of script: arch-macosx-gnu-O-omp, ignoring environment:
>>> arch-macosx-gnu-g
>>>          TESTING: configureLibraryOptions from
>>> PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:37)
>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>> for details):
>>> Must use --with-log=0 with --with-threadsafety
>>> On Mon, Apr 13, 2020 at 2:54 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> On Mon, Apr 13, 2020 at 12:06 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> BTW, I can build on SUMMIT with logging and OMP, apparently. I also
>>>>> seem to be able to build with debugging. Both of which are not allowed
>>>>> according the the docs. I am puzzled.
>>>>  What are "the docs"?
>>>>> On Mon, Apr 13, 2020 at 12:05 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> I think the problem is that you have to turn off logging with openmp
>>>>>> and the (newish) GPU timers did not protect their timers.
>>>>>> I don't see a good reason to require logging be turned off with OMP.
>>>>>> We could use PETSC_HAVE_THREADSAFETY to protect logs that we care about
>>>>>> (eg, in MatSetValues) and as users discover more things that they want to
>>>>>> call in an OMP thread block, then tell them to turn logging off and we will
>>>>>> fix it when we can.
>>>>>> Any thoughts on the idea of letting users keep logging with openmp?
>>>>>> On Mon, Apr 13, 2020 at 11:40 AM Junchao Zhang <
>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>> Yes. Looks we need to include petsclog.h. Don't know why OMP
>>>>>>> triggered the error.
>>>>>>> --Junchao Zhang
>>>>>>> On Mon, Apr 13, 2020 at 9:59 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> Should I do an MR to fix this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200413/950eac4f/attachment-0001.html>
