[petsc-dev] DMGetNeighbors and DMPlex
    Matthew Knepley
    knepley at gmail.com
    Mon Apr 13 09:42:03 CDT 2020
On Mon, Apr 13, 2020 at 6:14 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> I’m trying to figure out why the result of DMGetNeighbors when a DMPlex is
> distributed with no overlap can be nonsymmetric.
Right now, the Plex function only calls PetscSFGetRootRanks(). It should
probably call PetscSFGetLeafRanks() as well and merge the lists.
Have time to make the fix? You could commit this nice test :)
    Matt
> Is this intended? If so, is there some other easy way to get the
> equivalent list as in the overlapping case (I’m interested in the list of
> ranks sharing at least one point)?
> Here is a MWE.
> $ patch -p1 < patch.txt
> $ cd src/dm/impls/plex/tests/
> $ make ex1
> $ mpirun -n 2 ./ex1 -dim 2 -cell_simplex 0 -interpolate -domain_shape box
> -domain_box_sizes 3,3 -test_redistribute
> 1 <— how come rank 0 has 1 neighbor
> 0 <— but rank 1 has 0 neighbor?
> -domain_box_sizes 3,3 -overlap 1
> 1
> 1
> Overlap: 1
> Thanks,
> Pierre
> diff --git a/src/dm/impls/plex/tests/ex1.c b/src/dm/impls/plex/tests/ex1.c
> index 4a5d051a66..ac2ce8eb20 100644
> --- a/src/dm/impls/plex/tests/ex1.c
> +++ b/src/dm/impls/plex/tests/ex1.c
> @@ -3,0 +4 @@ static char help[] = "Tests various DMPlex routines to
> construct, refine and dis
> +#include <petscsf.h>
> @@ -420,0 +422,8 @@ PetscErrorCode CreateMesh(MPI_Comm comm, AppCtx *user,
> DM *dm)
> +      PetscInt nranks;
> +      const PetscInt* ranks;
> +      PetscSF sf;
> +      ierr = DMGetPointSF(distributedMesh, &sf);CHKERRQ(ierr);
> +      ierr = PetscSFSetUp(sf);CHKERRQ(ierr);
> +      ierr = DMGetNeighbors(distributedMesh, &nranks,
> &ranks);CHKERRQ(ierr);
> +      ierr =
> PetscSynchronizedPrintf(PETSC_COMM_WORLD,"%D\n",nranks);CHKERRQ(ierr);
> +      ierr =
> PetscSynchronizedFlush(PETSC_COMM_WORLD,PETSC_STDOUT);CHKERRQ(ierr);
> @@ -434,0 +444,8 @@ PetscErrorCode CreateMesh(MPI_Comm comm, AppCtx *user,
> DM *dm)
> +      PetscInt nranks;
> +      PetscSF sf;
> +      ierr = DMGetPointSF(overlapMesh, &sf);CHKERRQ(ierr);
> +      ierr = DMGetNeighbors(overlapMesh, &nranks, &ranks);CHKERRQ(ierr);
> +      ierr =
> +      ierr =
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200413/0ee02301/attachment.html>
