[petsc-dev] Issue with make test and globsearch
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Apr  9 12:25:47 CDT 2020
attached
May this issue be related with the fact that src/mat/tests/ex1.c does not
have a suffix: 1 nor a default test?
Il giorno gio 9 apr 2020 alle ore 20:23 Scott Kruger <kruger at txcorp.com> ha
scritto:
> Can you send me these files?
> $PETSC_ARCH/tests/datatest.pkl
> $PETSC_ARCH/tests/testfiles
> Thanks,
> Scott
> On 4/9/20 10:47 AM, Stefano Zampini wrote:
> > [szampini at localhost petsc]$ make -f gmakefile.test test
> globsearch='mat_*'
> > Using MAKEFLAGS: -- globsearch=mat_*
> > make: *** No rule to make target 'mat_tests-ex1_1', needed by
> > 'report_tests'.  Stop.
> > Stefano
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200409/7b3f2597/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200409/7b3f2597/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200409/7b3f2597/attachment-0003.obj>
