[petsc-dev] MatSetValuesBlocked not inserting values
Jacob Faibussowitsch jacob.fai at gmail.com
Wed Apr 8 17:16:06 CDT 2020
No I also printed those out and checked them. They return 0->nGlobalAtoms. The globalID-1 is because the other library which is assigning these ID's (LAMMPS) doesn’t use 0-based indexing for the global indices for whatever reason.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Apr 8, 2020, at 5:14 PM, Jed Brown <jed at jedbrown.org> wrote:
> Sure, but could you have computed them as a negative number here?
> Jacob Faibussowitsch <jacob.fai at gmail.com> writes:
>> Supposed to be the block row and column indices. So they are the atom global IDs.
>> Best regards,
>>> On Apr 8, 2020, at 4:29 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> What are idxm[0] and idxn[0] in this code?
>>>> Hello All,
>>>> I am using MATSBAIJ to make a symmetric hamiltonian matrix, but for some reason MatSetValuesBlocked isn’t inserting anything.
>>>> Setup:
>>>> I want a 4n x 4n symmetric matrix, where each MatSetValuesBlocked inserts a 4x4 sub-matrix of values into the global matrix, positioned by the global ID of two atoms that I am extracting. So the 4x4 interaction sub matrix between atom 1 and atom 4 will be in rows 0-4 and cols 16-20.
>>>> My non-working implementation:
>>>> PetscInt bs = 4;
>>>> ierr = MatCreateSBAIJ(comm, bs, bs*nLocalAtoms, bs*nLocalAtoms, PETSC_DETERMINE, PETSC_DETERMINE, 1, NULL, 1, NULL, H);CHKERRQ(ierr);
>>>> ierr = MatSetOption(*H, MAT_SYMMETRIC, PETSC_TRUE);CHKERRQ(ierr);
>>>> ierr = MatSetUp(*H);CHKERRQ(ierr);
>>>> START LOOP {
>>>> Calculations...
>>>> const PetscScalar  valmat[16] = {Es[0], Es[1], Es[2], Es[3], Ex[0], Ex[1], Ex[2], Ex[3], Ey[0], Ey[1], Ey[2], Ey[3], Ez[0], Ez[1], Ez[2], Ez[3]};
>>>> PetscInt                  idxm[1], idxn[1];
>>>> PetscInt                  m = 1, n = 1;
>>>> if (globalIDs[i] < globalIDs[neighidx[0]]-1) {
>>>> 	// Insert in upper triangular
>>>>       idxm[0] = globalIDs[i]-1;
>>>>       idxn[0] = globalIDs[neighidx[0]]-1;
>>>> } else {
>>>>       // swap so we insert on upper triangular
>>>>       idxn[0] = globalIDs[i]-1;
>>>>       idxm[0] = globalIDs[neighidx[0]]-1;
>>>> ierr = MatSetValuesBlocked(*H, m, (const PetscInt *) idxm, n, (const PetscInt *) idxn, valmat, INSERT_VALUES);CHKERRQ(ierr);
>>>> } END LOOP
>>>> ierr = MatAssemblyBegin(*H, MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>> ierr = MatAssemblyEnd(*H, MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>> RETURN H
>>>> Output from -mat_view:
>>>> Mat Object: 2 MPI processes
>>>> type: mpisbaij
>>>> row 0:
>>>> row 1:
>>>> row 2:
>>>> row 3:
>>>> row 4:
>>>> row 5:
>>>> row 6:
>>>> row 7:
>>>> row 8:
>>>> row 9:
>>>> row 10:
>>>> row 11:
>>>> row 12:
>>>> row 13:
>>>> row 14:
>>>> row 15:
>>>> I also checked -info :mat: and it also reports X unneeded storage space but more importantly, 0 used. I am not sure what is going wrong here.
>>>> Best regards,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200408/b306828d/attachment.html>
