[petsc-dev] snes_tutorials-ex19_cuda_1
    Junchao Zhang
    junchao.zhang at gmail.com
    Fri Apr  3 22:41:50 CDT 2020
Satish,
I have a MR !2688 to fix it.  How to revert your revert to get the MR
actually tested?
--Junchao Zhang
On Fri, Apr 3, 2020 at 9:11 PM Satish Balay <balay at mcs.anl.gov> wrote:
> https://gitlab.com/petsc/petsc/pipelines/132414153/builds
> this pipeline had 1 rerun for  linux-cuda-double  and 5 reruns for
> linux-c-exodus-dbg
> I've reverted 2655 for now. We can revert this once the issue is resolved.
> Satish
> On Thu, 2 Apr 2020, Satish Balay via petsc-dev wrote:
> > Perhaps we should revert this merge - so that the CI is stabilized for
> now.
> > Satish
> > On Thu, 2 Apr 2020, Junchao Zhang wrote:
> > > Seems caused by MR 2655
> > > <https://gitlab.com/petsc/petsc/-/merge_requests/2655>.  I reverted
> it and
> > > tested in CI several times and the error did not appear. Let's assume
> the
> > > MR has a bug. I am looking into it.
> > > --Junchao Zhang
> > > On Thu, Apr 2, 2020 at 10:58 AM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > That was a different error. This does keep coming up occasionally.
> > > > https://gitlab.com/petsc/petsc/-/issues/360#note_250063306
> > > > The current issue is:
> > > > https://gitlab.com/petsc/petsc/-/issues/360#note_314185490
> > > > Satish
> > > > On Thu, 2 Apr 2020, Karl Rupp wrote:
> > > > > The fluctuations in this example have been fixed a few months ago;
> the
> > > > issue
> > > > > was the use of multiple streams instead of a single one. Maybe
> > > > additional CUDA
> > > > > streams have been reintroduced recently?
> > > > > Best regards,
> > > > > Karli
> > > > > On 4/2/20 5:02 AM, Junchao Zhang wrote:
> > > > > > I could not reproduce it locally. Even in the CI, it is random.
> > > > > > --Junchao Zhang
> > > > > > On Wed, Apr 1, 2020 at 7:47 PM Matthew Knepley <
> knepley at gmail.com
> > > > > > <mailto:knepley at gmail.com>> wrote:
> > > > > >     I saw Satish talking about this on the CI Tracker MR.
> > > > > >         Matt
> > > > > >     On Wed, Apr 1, 2020 at 8:36 PM Lisandro Dalcin <
> dalcinl at gmail.com
> > > > > >     <mailto:dalcinl at gmail.com>> wrote:
> > > > > >         Well, my request will not fix the problem:
> > > > > >         https://gitlab.com/petsc/petsc/-/jobs/495147366#L5231
> > > > > >         On Thu, 2 Apr 2020 at 03:26, Lisandro Dalcin <
> > > > > >             Can anyone messing with CPUs please update test
> > > > > >             snes_tutorials-ex19_cuda_1 to use -ksp_monitor_short
> and
> > > > > >             update its output with REPLACE=1 ?
> > > > > >             Please do it in maint, or cherry-pick if already
> fixed in
> > > > > >             master.
> > > > > >             Regards,
> > > > > >             Lisandro Dalcin
> > > > > >             Research Scientist
> > > > > >             Extreme Computing Research Center (ECRC)
> > > > > >             King Abdullah University of Science and Technology
> (KAUST)
> > > > > >             http://ecrc.kaust.edu.sa/
> > > > > >         Lisandro Dalcin
> > > > > >         Research Scientist
> (KAUST)
> > > > > >     What most experimenters take for granted before they begin
> their
> > > > > >     experiments is infinitely more interesting than any results
> to
> > > > which
> > > > > >     their experiments lead.
> > > > > >     -- Norbert Wiener
> > > > > >     https://www.cse.buffalo.edu/~knepley/
> > > > > >     <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200403/083ddc54/attachment.html>
