[petsc-dev] failed rebase
    Mark Adams
    mfadams at lbl.gov
    Fri Apr  3 10:56:58 CDT 2020
On Fri, Apr 3, 2020 at 10:27 AM Satish Balay <balay at mcs.anl.gov> wrote:
> I attempted a rebase - and I get the following diff from yours. You might
> want to verify.
These are small fixes that I did this morning.
> $ git diff
> origin/mark/feature-xgc-interface-rebase..mark/feature-xgc-interface-rebase-local
> diff --git a/include/petscdmplex.h b/include/petscdmplex.h
> index cb464bbe77..ed99700499 100644
> --- a/include/petscdmplex.h
> +++ b/include/petscdmplex.h
> @@ -474,7 +474,6 @@ PETSC_EXTERN PetscErrorCode
> DMPlexCellRefinerRefine(DMPlexCellRefiner, DMPolytop
> DMPlexCellRefinerGetAffineTransforms(DMPlexCellRefiner, DMPolytopeType,
> PetscInt *, PetscReal *[], PetscReal *[], PetscReal *[]);
> DMPlexCellRefinerGetAffineFaceTransforms(DMPlexCellRefiner, DMPolytopeType,
> PetscInt *, PetscReal *[], PetscReal *[], PetscReal *[], PetscReal *[]);
>  PETSC_EXTERN PetscErrorCode DMPlexRefineUniform(DM, DMPlexCellRefiner, DM
>  PETSC_EXTERN PetscErrorCode DMPlexFPPrintNorms(Vec, PetscInt);
>  PETSC_EXTERN PetscErrorCode DMPlexFPCreate2D(MPI_Comm, const PetscInt,
> const PetscInt, const PetscInt[], const double[], const double[], const
> PetscInt, const PetscInt[], const PetscScalar[/* ? */], DM *dm);
> DMPlexFPCreateVelocitySpace(MPI_Comm,PetscInt,const char[],Vec*,DM*);
> diff --git a/src/dm/impls/plex/tutorials/ex11.c
> b/src/dm/impls/plex/tutorials/ex11.c
> index b28864ac89..29ca44f422 100644
> --- a/src/dm/impls/plex/tutorials/ex11.c
> +++ b/src/dm/impls/plex/tutorials/ex11.c
> @@ -648,7 +648,6 @@ PetscPrintf(PETSC_COMM_SELF, "\t\t***** FormRHSSource:
> have new_imp_rate= %10.3e
>        ierr = PetscObjectSetName((PetscObject)S, "src");CHKERRQ(ierr);
>        ierr =
> VecViewFromOptions(S,NULL,"-vec_view_diagnostics");CHKERRQ(ierr);
>        ierr = MatMult(ctx->M,S,rectx->imp_src);CHKERRQ(ierr);
> -      ierr = VecCopy(S,rectx->imp_src);CHKERRQ(ierr);
>        ierr = VecDestroy(&S);CHKERRQ(ierr);
>      ierr = VecCopy(rectx->imp_src,F);CHKERRQ(ierr);
> @@ -711,7 +710,7 @@ static PetscErrorCode stepSrc(PetscReal time, PetscInt
> step, PetscReal dt, Petsc
>    REctx         *rectx;
>    PetscFunctionBegin;
>    rectx = (REctx*)ctx->data;
> -  if (time >= rectx->pulse_start) *rho = rectx->pulse_rate;
> +  if (time > 1.e+5) *rho = rectx->pulse_rate; /* turned off */
>    else *rho = 0.;
>    PetscFunctionReturn(0);
> $ ls src/dm/impls/plex/examples/tutorials/
> doc/  ex10.c  ex10f90.F90  ex11.c  output/
Old files from move. I removed them. Thanks,
> This should now be in src/dm/impls/plex/tutorials/
> Regarding the primary issue: configure, the primary error is not logged in
> configure.log. Running manually - I get:
> bfort terminating at 664: Exceeded output count limit!
> $ grep '/*@' *.c |wc -l
> 600
> This single dir creates 600 man pages? Perhaps its time to reorganize plex
> into multiple dirs?
> Satish
> On Fri, 3 Apr 2020, Mark Adams wrote:
> > Satish, I tried again from scratch see the same thing.
> > I pushed this.
> > Thanks
> > 09:35 mark/feature-xgc-interface-rebase= ~/Codes/petsc$ git rebase
> > origin/master
> > First, rewinding head to replay your work on top of it...
> > Applying: starting rebase branch
> > Using index info to reconstruct a base tree...
> > M       include/petsc/private/dmpleximpl.h
> > M       include/petscdmplex.h
> > M       src/dm/impls/plex/makefile
> > .git/rebase-apply/patch:2620: trailing whitespace.
> >       for (d=0;d<src->dim;d++) *pp++ = src->df[d][s][idx];
> > warning: 1 line adds whitespace errors.
> > Falling back to patching base and 3-way merge...
> > Auto-merging src/dm/impls/plex/makefile
> > Auto-merging include/petscdmplex.h
> > CONFLICT (content): Merge conflict in include/petscdmplex.h
> > Auto-merging include/petsc/private/dmpleximpl.h
> > error: Failed to merge in the changes.
> > Patch failed at 0001 starting rebase branch
> > hint: Use 'git am --show-current-patch' to see the failed patch
> > Resolve all conflicts manually, mark them as resolved with
> > "git add/rm <conflicted_files>", then run "git rebase --continue".
> > You can instead skip this commit: run "git rebase --skip".
> > To abort and get back to the state before "git rebase", run "git rebase
> > --abort".
> > 09:36 1 mark/feature-xgc-interface-rebase *+|REBASE 1/19 ~/Codes/petsc$
> vi
> > 09:37 mark/feature-xgc-interface-rebase *+|REBASE 1/19 ~/Codes/petsc$ git
> > add include/petscdmplex.h
> > 09:37 mark/feature-xgc-interface-rebase +|REBASE 1/19 ~/Codes/petsc$ git
> > rebase --continue
> > Applying: manual merge
> > Applying: RE test
> > Applying: remove Ehat
> > Applying: clean up interface, redo regression tests, found false
> negatives
> > Applying: change Ec
> > Applying: tweek griding
> > Applying: clean up, working on impurity injection
> > Applying: fixed quench and pulse test
> > Applying: hardwired CUDA kernel for DIM, added presolve in ex11
> > Applying: added guard
> > Applying: starting to get E field added
> > Applying: doc
> > Applying: fix test params
> > Applying: remove comment
> > Applying: updated test syntax
> > Applying: cleaned up flags
> > Applying: fixed soruce bug
> > 09:37 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$ rm -fr
> > arch-macosx-gnu-g/
> > 09:38 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$
> > ../arch-macosx-gnu-g.py
> >              Configuring PETSc to compile on your system
> >                                                    ***** WARNING: You
> have
> > an older version of Gnu make, it will work,
> >                          but may not support all the parallel testing
> > options. You can install the
> >      latest Gnu make with your package manager, such as brew or macports,
> > or use
> >                                                          the
> > --download-make option to get the latest Gnu make *****
> >                                                    Trying to download
> git://
> > https://bitbucket.org/petsc/pkg-sowing.git for SOWING
> >                                                    Running configure on
> > SOWING; this may take several minutes
> >                                                    Running make on
> SOWING;
> >                                                    Running make install
> on
> >                                              TESTING: checkSharedLibrary
> > from config.packages.sowing(config/BuildSystem/config/package.py:926)
> >         CONFIGURATION CRASH  (Please send configure.log to
> > petsc-maint at mcs.anl.gov)
> > 09:40 1 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$
> > On Fri, Apr 3, 2020 at 8:17 AM Mark Adams <mfadams at lbl.gov> wrote:
> > > On Thu, Apr 2, 2020 at 11:05 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > >> My OS build also went through. Looks like you haven't pushed [force
> > >> update] this branch - so I'm testing with something totally different.
> > > Yes, I have a <> after a rebase.  Do you want me to push it? Or should
> I
> > > just start over? I thought I started with a clean version of my code
> from
> > > the repo.
> > > Thanks,
> > >> So likely something in your rebased sources is causing bfort to fail..
> > >> Satish
> > >> On Thu, 2 Apr 2020, Mark Adams wrote:
> > >> > I see:
> > >> > 22:46 128 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$ git
> status
> > >> > On branch mark/feature-xgc-interface-rebase
> > >> > Your branch and 'origin/mark/feature-xgc-interface-rebase' have
> > >> diverged,
> > >> > and have 130 and 18 different commits each, respectively.
> > >> >   (use "git pull" to merge the remote branch into yours)
> > >> > Untracked files:
> > >> >   (use "git add <file>..." to include in what will be committed)
> > >> >         out2.txt
> > >> >         src/dm/impls/plex/examples/tutorials/Landau/
> > >> > On Thu, Apr 2, 2020 at 10:45 PM Mark Adams <mfadams at lbl.gov> wrote:
> > >> > > On Thu, Apr 2, 2020 at 10:33 PM Satish Balay <balay at mcs.anl.gov>
> > >> wrote:
> > >> > >> Is this branch mark/feature-xgc-interface-rebase pushed?
> > >> > > yes.
> > >> > >> I had done a build with the current state of it - and the build
> went
> > >> > >> through fine. This was on linux.
> > >> > >> Will try OSX now.
> > >> > >> Satish
> > >> > >> > Note, when I rebased I got one conflict, in a header where I
> added
> > >> > >> stuff at
> > >> > >> > the end and master did also so I just kept them both and
> continued.
> > >> > >> > Other than that it was a clean rebase.
> > >> > >> > On Thu, Apr 2, 2020 at 10:15 PM Mark Adams <mfadams at lbl.gov>
> > >> wrote:
> > >> > >> > > On Thu, Apr 2, 2020 at 9:32 PM Satish Balay <
> > >> > >> wrote:
> > >> > >> > >> can you try this in a local clone [same branch] and see if
> that
> > >> > >> works?
> > >> > >> > >> cd /Users/markadams/Codes
> > >> > >> > >> git clone petsc petsc-test
> > >> > >> > >> cd petsc-test
> > >> > >> > >> ./configure ...
> > >> > >> > >> Satish
> > >> > >> > >> > I tried to rebase mark/feature-xgc-interface-rebase with
> > >> master
> > >> > >> and I
> > >> > >> > >> get
> > >> > >> > >> > this.
> > >> > >> > >> > I of course deleted the arch directory.
> > >> > >> > >> > Thanks,
> > >> > >> > >> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200403/7722b2fb/attachment-0001.html>
