[petsc-dev] failed rebase
    Mark Adams
    mfadams at lbl.gov
    Thu Apr  2 21:55:51 CDT 2020
I see:
22:46 128 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$ git status
On branch mark/feature-xgc-interface-rebase
Your branch and 'origin/mark/feature-xgc-interface-rebase' have diverged,
and have 130 and 18 different commits each, respectively.
  (use "git pull" to merge the remote branch into yours)
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        out2.txt
        src/dm/impls/plex/examples/tutorials/Landau/
On Thu, Apr 2, 2020 at 10:45 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Apr 2, 2020 at 10:33 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> Is this branch mark/feature-xgc-interface-rebase pushed?
> yes.
>> I had done a build with the current state of it - and the build went
>> through fine. This was on linux.
>> Will try OSX now.
>> Satish
>> On Thu, 2 Apr 2020, Mark Adams wrote:
>> > Note, when I rebased I got one conflict, in a header where I added
>> stuff at
>> > the end and master did also so I just kept them both and continued.
>> > Other than that it was a clean rebase.
>> > On Thu, Apr 2, 2020 at 10:15 PM Mark Adams <mfadams at lbl.gov> wrote:
>> > > On Thu, Apr 2, 2020 at 9:32 PM Satish Balay <balay at mcs.anl.gov>
>> wrote:
>> > >> can you try this in a local clone [same branch] and see if that
>> works?
>> > >> cd /Users/markadams/Codes
>> > >> git clone petsc petsc-test
>> > >> cd petsc-test
>> > >> ./configure ...
>> > >> Satish
>> > >> > I tried to rebase mark/feature-xgc-interface-rebase with master
>> and I
>> > >> get
>> > >> > this.
>> > >> > I of course deleted the arch directory.
>> > >> > Thanks,
>> > >> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200402/d2b5f6f3/attachment.html>
