[petsc-dev] failed rebase
    Satish Balay
    balay at mcs.anl.gov
    Thu Apr  2 21:33:53 CDT 2020
Is this branch mark/feature-xgc-interface-rebase pushed? I had done a build with the current state of it - and the build went through fine. This was on linux.
Will try OSX now.
Satish
On Thu, 2 Apr 2020, Mark Adams wrote:
> Note, when I rebased I got one conflict, in a header where I added stuff at
> the end and master did also so I just kept them both and continued.
> Other than that it was a clean rebase.
> On Thu, Apr 2, 2020 at 10:15 PM Mark Adams <mfadams at lbl.gov> wrote:
> > On Thu, Apr 2, 2020 at 9:32 PM Satish Balay <balay at mcs.anl.gov> wrote:
> >> can you try this in a local clone [same branch] and see if that works?
> >> cd /Users/markadams/Codes
> >> git clone petsc petsc-test
> >> cd petsc-test
> >> ./configure ...
> >> Satish
> >> > I tried to rebase mark/feature-xgc-interface-rebase with master and I
> >> get
> >> > this.
> >> > I of course deleted the arch directory.
> >> > Thanks,
> >> > Mark
