[petsc-dev] snes_tutorials-ex19_cuda_1
    Junchao Zhang
    junchao.zhang at gmail.com
    Thu Apr  2 11:27:39 CDT 2020
Seems caused by MR 2655
<https://gitlab.com/petsc/petsc/-/merge_requests/2655>.  I reverted it and
tested in CI several times and the error did not appear. Let's assume the
MR has a bug. I am looking into it.
--Junchao Zhang
On Thu, Apr 2, 2020 at 10:58 AM Satish Balay <balay at mcs.anl.gov> wrote:
> That was a different error. This does keep coming up occasionally.
> https://gitlab.com/petsc/petsc/-/issues/360#note_250063306
> The current issue is:
> https://gitlab.com/petsc/petsc/-/issues/360#note_314185490
> Satish
> On Thu, 2 Apr 2020, Karl Rupp wrote:
> > The fluctuations in this example have been fixed a few months ago; the
> issue
> > was the use of multiple streams instead of a single one. Maybe
> additional CUDA
> > streams have been reintroduced recently?
> > Best regards,
> > Karli
> > On 4/2/20 5:02 AM, Junchao Zhang wrote:
> > > I could not reproduce it locally. Even in the CI, it is random.
> > > --Junchao Zhang
> > > On Wed, Apr 1, 2020 at 7:47 PM Matthew Knepley <knepley at gmail.com
> > > <mailto:knepley at gmail.com>> wrote:
> > >     I saw Satish talking about this on the CI Tracker MR.
> > >         Matt
> > >     On Wed, Apr 1, 2020 at 8:36 PM Lisandro Dalcin <dalcinl at gmail.com
> > >     <mailto:dalcinl at gmail.com>> wrote:
> > >         Well, my request will not fix the problem:
> > >         https://gitlab.com/petsc/petsc/-/jobs/495147366#L5231
> > >         On Thu, 2 Apr 2020 at 03:26, Lisandro Dalcin <
> > >             Can anyone messing with CPUs please update test
> > >             snes_tutorials-ex19_cuda_1 to use -ksp_monitor_short and
> > >             update its output with REPLACE=1 ?
> > >             Please do it in maint, or cherry-pick if already fixed in
> > >             master.
> > >             Regards,
> > >             Lisandro Dalcin
> > >             Research Scientist
> > >             Extreme Computing Research Center (ECRC)
> > >             King Abdullah University of Science and Technology (KAUST)
> > >             http://ecrc.kaust.edu.sa/
> > >         Lisandro Dalcin
> > >         Research Scientist
> > >     What most experimenters take for granted before they begin their
> > >     experiments is infinitely more interesting than any results to
> which
> > >     their experiments lead.
> > >     -- Norbert Wiener
> > >     https://www.cse.buffalo.edu/~knepley/
> > >     <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200402/a055510c/attachment.html>
