[petsc-dev] getting eigen estimates from GAMG to CHEBY
Mark Adams
mfadams at lbl.gov
Fri Sep 27 11:52:18 CDT 2019
As I recall we attached the eigenstates to the matrix. Is that old attach
mechanism still the used/recommended? Or is there a better way to do this
now?
On Thu, Sep 26, 2019 at 7:45 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Okay, it seems like they should be stored in GAMG.
> Before we stored them in the matrix. When you get to the test in Cheby you
> don't have caller anymore (GAMG).
>> Why would the PC type change anything?
> Oh, the eigenvalues are the preconditioned ones, the PC (Jacobi) matters
> but it is not too sensitive to normal PCs that you would use in a smoother
> and it is probably not an understatement.
>> Thanks,
>> Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190927/91b385fd/attachment.html>
