[petsc-dev] error with karlrupp/fix-cuda-streams
Balay, Satish
balay at mcs.anl.gov
Thu Sep 26 09:18:27 CDT 2019
Mark,
The branch karlrupp/fix-cuda-streams is already merged to master. [and
the branch is now deleted]
I guess - if you wish to compare the difference this feature makes - you
can compare with master snapshot before this merge.
i.e compare master (includes karlrupp/fix-cuda-streams feature) and daa275bd14416591c3d721c1d33cf5d68c84dfcc [master before this merge]
Satish
On Thu, 26 Sep 2019, Mark Adams via petsc-dev wrote:
> Karl, I have it running but I am not seeing any difference from master. I
> wonder if I have the right version:
> Using Petsc Development GIT revision: v3.11.3-2207-ga8e311a
> I could not find karlrupp/fix-cuda-streams on the gitlab page to check your
> last commit SHA1 (???), and now I get:
> 08:37 karlrupp/fix-cuda-streams= ~/petsc-karl$ git pull origin
> fatal: Couldn't find remote ref karlrupp/fix-cuda-streams
> Unexpected end of command stream
> 10:09 1 karlrupp/fix-cuda-streams= ~/petsc-karl$
> On Wed, Sep 25, 2019 at 8:51 AM Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> > > I double checked that a clean build of your (master) branch has this
> > > error by my branch (mark/fix-cuda-with-gamg-pintocpu), which may include
> > > stuff from Barry that is not yet in master, works.
> > so did master work recently (i.e. right before my branch got merged)?
> > Best regards,
> > Karli
> > > On Wed, Sep 25, 2019 at 5:26 AM Karl Rupp via petsc-dev
> > > <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
> > > On 9/25/19 11:12 AM, Mark Adams via petsc-dev wrote:
> > > > I am using karlrupp/fix-cuda-streams, merged with master, and I
> > > get this
> > > > error:
> > > > Could not execute "['jsrun -g\\ 1 -c\\ 1 -a\\ 1 --oversubscribe
> > -n 1
> > > > printenv']":
> > > > Error, invalid argument: 1
> > > > My branch mark/fix-cuda-with-gamg-pintocpu seems to work but I
> > > did edit
> > > > the jsrun command but Karl's branch still fails. (SUMMIT was down
> > > today
> > > > so there could have been updates).
> > > > Any suggestions?
> > > Looks very much like a systems issue to me.
> > > Best regards,
> > > Karli
