[petsc-dev] error with karlrupp/fix-cuda-streams
Mark Adams mfadams at lbl.gov
Wed Sep 25 14:28:56 CDT 2019
> Yes, it's supported, but it's a little different than what "-n" usually
> does in mpiexec, where it means the number of processes. For 'jsrun', it
> means the number of resource sets, which is multiplied by the "tasks per
> resource set" specified by "-a" to get the MPI process count. I think if we
> can specify that "-a 1" is part of our "mpiexec", then we should be OK with
> using -n as PETSc normally does.
jsrun does not run with just -n on SUMMIT. I have found that it works with
adding -g 1.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/acc502a7/attachment.html>
